Question about Garden
How do I remove starter & replace brushes in a 446 Case garden tractor.
    Top Expert:
  • Garden Master
  • 10,627 Answers
Check first see if you can buy brushes might have to buy whole starter
Posted on Dec 18, 2019
6ya staff
SOURCE:
Anonymous
  • 13 Answers
SOURCE: replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Posted on Mar 13, 2009
Anonymous
  • 246 Answers
SOURCE: Concerning a Craftsman 24hp garden tractor. The
Hello jejodaro:
>>You have to Hold the Shaft on the Blade Side with a Pipe or Strap Wrench or Depending on the Model, you can Block the Blade an Hold the Shaft so the Pulley Nut can be Loosened/Removed.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy. Thanks.
Respectfully
John
Posted on Apr 21, 2009
Anonymous
SOURCE: removal of the electric(coil) clutch that engages
Problem has b een resolved. I found a pair of channel-loks narrow enough to get down on the back side of the motor. Was able to get a good hold on the coupling that drives the hydraulic pump and loosen the bolt that held the old PTO electric clutch. Once the bolt was removed, it dissassembled very easily. Installation of the new clutch, although it is different from old one, went well also. Be sure to install new unit as one unit,(not in separate pieces).
Thanks for you concern, as I was at a standstill for awhile. Thanks for being there.
Lynn W. Smith
Posted on May 18, 2009
mudbay43
SOURCE: Free download service manual 224
I have recently put in a new soelnoid on my case 224/new battery. Ignition starter wont work off of key and now no spark off of plug. I was told maybe the coil?? I cant find a manual either so Im very much in the dark. Any help would be greatly appreciated
Posted on Jun 10, 2011
Anthony Browning
  • 640 Answers
SOURCE: Do you have a wiring
Generally starters ground through the engine, so that only leaves the positive wire. That one comes from the starting solinoid. Starting solinoid gets power from the battery. Anyway these wires are the biggest ones on the machine including the negative/ground wire from the battery.
I hope this helps.
Posted on Jul 30, 2011
Engine hard to start
starter brushes bad, replace starter
Jun 21, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Can I get a manual for a case tractor Model Onan 446-76?
Goggle it. manual for case model onan 446-76
Apr 30, 2015 | Garden
Turn key on will not start with new battery power to starter moter is good
Are you pushing in the clutch? If yes, then it might be the clutch switch. Most mowers need the clutch in to start. I have wasted many hours by not knowing that.
Apr 09, 2014 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Starter motor wont engage checked brushes and movement small what i persume soleniod attached the side of starter just clicks
Alot of the time a clicking sound indicates a dead battery. It happens when there isn't enough power to fully engage the starter but just enough to engage solenoid. I would check your battery and all connections, including ground wires, battery wires and solenoid wires. Take a wire brush to them and clean them up and reinstall them. If that doesn't work, remove your starter and bench test it by hooking up a good battery to the lead that solenoid goes to and ground the other. If it passes the bench test your solenoid probably needs replaced. If it fails the problem is in your starter. Good luck! FYI, remove battery leads while removing starter and other wires for safety when cleaning.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Mar 16, 2014 | Garden
Valve adjustment
Sounds like a bad ground, bad wire connection or a starter going bad. The most overlooked thing when it comes to wiring are ground connections. Remove grounds and clean with a wire brush or emery cloth. Also, do this on solenoid, starter and battery connections too. If problem persists I would recommend rebuilding the starter. Good luck and happy wrenching!
Sep 13, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Ford 8n Is It Time to Replace the Starter?
Bad brushes it is not making contact with the brushes.
Jun 22, 2013 | Ford 8n,9n,2n, Tractor Starter With Drive
How to diagnose a starter problem
Hi rojoby
Remove the starter, hook up the (+) Hot wire to the post of the starter, then take the ground wire(-) from the battery and ground it to the outside case of the starter...if it runs, then the starter is good...if not, replace the starter as it is faulty.
If if runs, then check/replace the starter solinoid, it could be faulty
Please take time to rate me
Bud
Nov 25, 2012 | John Deere 300 / 316 Hydrostatic Tractors...
John Deere 165 will not turn over. New battery has fuel. Engine clicks one time when I turn the key. Could this be starter or solenoid? How do I trouble shoot?
"One click" tells me it's a connection issue. Remove and wire brush the ground and battery cable connections at the battery, chassis, starter and starter solenoid.
May 22, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Can not remove starter
You mean you cannont physically take it out. Is the starter drive bound up with the ring gear? If thats the case put the tractor in high gear and rock it by pushing on a rear tire to unstick the drive... Need more info.
Aug 20, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
How to fit brushes to b+s 12 hp starter motor about 8years old
sounds like you removed the rear cover instead of dismantling the starter from the gear side- good luck putting it together that way - you need to dismantle from the gear side so you can put the armature into the brushes with no prob -
Oct 08, 2008 | Garden
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
