SOURCE: The clicker will not lock or unlock the front
It sounds like your remote needs a new battery.
Your user manual should tell you what type... else, remove the old battery and find an equivalent.
Hope this helps... Good luck.
SOURCE: 1993 Ford Tempo rear doors won't open
This is most likly a fuse problem. Check your fuses that say doors on the diagram. If you have o diagram then pull one fuse at a time and look to see if the wire inside is burnt or broken. Replace if it is. If not then replace the fuse back to the same spot and move to the next fuse. If you find one that is burnt then replace with same amp type fuse. There may be more then one that has burnt so go ahead and check them all. Keep me informed and I will continue other trouble shooting ideas if this did not fix the problem, Good Luck, The Raz
SOURCE: chamberlain universal clicker klik1u clicker will
If the door starts to close and then the main lights flash 10 times and the door reverses to the open position you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit.
SOURCE: Thought I lost the Clicker
Reset your whole unit using the reset button on the door actuator and then reprogram it. Start fresh by temporarily removing the battery from the remote as well.
SOURCE: We have the chamberlain universal clicker klik1u
Hello iris.... Your remote control needs a new battery. Once you install the battery check to see if it works. If not, then reprogram the remote by pushing the programming button on the back of the garage door motor, then while it is flashing push the button on the remote to reprogram it. Joe
