I fell Saturday and cut my face it is like a rug burn one inch round
SOURCE: transmission fluid leaking
Bars leak is ok, but if it is a seal, you'll need to drop the tranny pan and replace it. I don't know about Mercedes, but usually you have to remove the exaust pipes to take the pan off.
SOURCE: need to change hydro fluid, what sould I use
is it a Massy?
Do not use eng oil!!!
Kubota UDT, Case IH hy-tran ultra oils will work on most.
SOURCE: oil leak from rear main seal 92 jeep cheeroke
remove transmission, remove flywheel, pry old seal out with seal remove or a screwdriver careful not to damage the block or crank. Clean surface with carberater cleaner or brake cleaner. Tap ne seal in with flat end of ball ping hammer. Put transmission back in.
SOURCE: my 1994 surburban Power brake units using the
You need to either have the hydro-booster rebuilt or buy a new one.
SOURCE: i know i need trans
your transmission is going to act poorly when it is low on fluid. Replace the seals before you break the transmission.
