Question about Samsung Microwave Ovens
How to remove control panel on samsung microwave model me18h704sfs
6ya staff
SOURCE:
Anonymous
SOURCE: How do I remove the control panel on model JE2160
You need to take the back cover off using a special tork wrench. If you don't have one a thin blade screw driver usually works. after getting the back cover off access is pretty easy to remove the screws from the panel. Make sure to discharge the capacitor before attempting any repairs and unplugged of course.
Posted on Jan 15, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: I need to replace the
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at
http://www.microwavedisplay.com and swing it down, but without disconnecting the wires.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
They're our favorite supplier.
Posted on Aug 23, 2010
TheMobilian
Dan Webster
  • 8220 Answers
Interesting video of how to get into a GE:
Service manual of a late model GE
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 18, 2011
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: how do i remove a control panel on a fridgidaire microwave model # PLEB30M9ECE I don't SEE any way to get it off
    Hello lisajwalls - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. Since this is a complex unit, typically this is something that you want a certified professional to install for you to prevent any exposure to radiation, safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process
    Posted on Nov 23, 2012
    Steve Papp
    • 1010 Answers
    SOURCE: SE ERROR
    I am not sure, ask the dealer
    Posted on Mar 13, 2013
    Need an owners manual for microwave model ME18H704SFS
    Try Googling (brand)(ME18H704SFS)(manual) without parens.
    Oct 13, 2017 | Microwave Ovens
    Accidently locked microwave model#ME18H7045FS can't unlock HELP
    try this. In future, the make helps :>) Also it is 'SF' not 5F. ME18H704SF
    To Set:
    Touch and hold the CANCEL/OFF Pad for
    three seconds. The Display shows "LOCKED"
    and the oven beeps.
    To Cancel:
    three seconds. "LOCKED" disappears from the
    Display and the oven beeps.
    Read more: http://forum.appliancepartspros.com/microwave-repair/441562-locked-microwave.html#ixzz4klZNPoYN
    http://www.appliancepartspros.com
    Here is your manual
    Samsung ME18H704SF User Manual Setting The Time Child Lock Options Kitchen...
    Here is the full details on you microwave from Samsung
    OTR Microwave with Ceramic Interior ME18H704SF Owner Information Support...
    Jun 22, 2017 | Microwave Ovens
    How to remove grease filter from a Samsung over the range microwave model number smh8165st
    The support page for model SMH8165S is here, and the first solution listed is how to replace the charcoal filter.
    You can also download your owner's manual.
    The charcoal filter is part number DE63-00367A and you can order it from the Pros here.
    - William E. Miller, AS-EET
    pupista@gmail.com
    http://www.MicrowaveControl.com
    Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
    May 01, 2017 | Samsung Microwave Ovens
    What does the E-11 message mean?
    Open circuit. Check sensor part, connection of sensor housing and PCB's connector.
    Sep 08, 2015 | Samsung Stainless Steel Over-The-Range...
    Need manual for samsung microwave above range
    https://www.manualowl.com/p/Samsung/ME18H704SFS%2FAA/Manual/221309
    Apr 19, 2015 | Samsung Microwave Ovens
    SE or 5E display on Samsung Model number SMH8165ST
    This microwave is a piece of garbage and Samsung are a bunch of idiots. I have a solution but first I will vent. One day after my warranty ran out, I started getting this SE error. They referred me to an authorized repairman, who said it would be $200 just to come and look at it! Thats for a microwave that sold for slightly more than that new! Samsung refuses to offer any do it yourself help. Some guy who works on microwaves told me to order a new control panel. part DE94-01806C It was about 36 dollars and took about 10 minutes to install. If you want to save a little, for 24 dollars you can just replace the membrane. That requires removing the existing membrane with a hair dryer and then carefully applying the new one. Seemed like too much trouble so I went with the control panel.
    Feb 04, 2012 | Samsung SMH9151 Microwave Oven
    Samsung microwave auto starting
    Please provide the model number of the microwave, and we'll be able to supply the part info. (Some Samsung models with this problem were part of a huge recall).
    Sep 04, 2008 | Microwave Ovens
    Microwave Ovens Logo
    60 people viewed this question
    Top Samsung Microwave Ovens Experts
    William Miller
    William Miller
    Gerry Harvey
    Gerry Harvey
    Ekse
    Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
