Microwave Ovens Logo
C
Chris Ward Posted on Nov 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a lamp bulb for my airequipt 125. The only specs I know are that it's a GE 4-prong tube style bulb 3.75" long. Anyone help?
ray gallant
Level 3:
Top Expert:
  • GE Master 74,163 Answers
  • Posted on Nov 19, 2020
ray gallant
GE Master
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
657094
Points
561709
1 Related Answer
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 28, 2009
SOURCE: Need to replace the surface light in GE JVM1490BD 003
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Or you can find helpful exploded view diagrams and order parts by entering your full model number here.
You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
2helpful
Changing interior light on GE jvm1790
1. Unplug Oven
2. Unscrew 2 screws on top front of oven
3. Pull of front vent (might need a little force the
first time but not to much or you will crack
plastic)
4. Unscrew screw facing you near the front that is
attached to metal plate on bottom of opening
behind the vent.
5. Pull out metal plate (box) carefully not to
damage any wires.
6.Bulb is in this metal box, pull out old one and
press the new one's prongs into holes (be
careful and gentle the bulb breaks easily,
don't try to pull it back out to see if it's all
the way in or you will most likely pull a
prong out of the bulb)
just firmly press bulb
into place.
6. Screw metal plate back in place.
7. Plug in oven and test bulb.
8. Unplug oven again and put vent back on with
the 2 screws.
9. Plug in, set clock and your done.
The first time I opened it up was to look for the bulb. The vent needed a little pulling to come off. The second time (to put in new bulb) it came off easier and whole thing took about 5 minutes.
Hope this helps.
Just in case: I am not a professional nor claim to be. This is based on my own experience. Yours may differ. Unless you feel totally comfortable you should contact a licensed electrician or an authorized service agent.
1helpful
7helpful
2answers
How to change the bulb in a jes1288sh02 ge microwave oven
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
You can find an exploded view showing the the lamp assembly (location refer# 280) here.
You can order the lamp assembly by entering your full model number here. It is part # WB36X951.
Replacement bulbs still do not work
Most electronic control boards have undersized circuit wires that can't handle a catastrophic lamp failure. The circuit trace will open like a fuse. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for open circuit trace.
4. Repair circuit trace...lights work again....
If you need further assistance, let me know
Regards,
reg501
2helpful
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
3helpful
Advantium Bulb replacement
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
2helpful
3answers
GE MICROWAVE
Dear Carluc
Right for this one, it is essential that you unplug the oven from the mains and leave it to dissipate any electrical current certainly for 6 hours. Once you have done this, you wil to get yourself a phillips head 6mm screwdiver and unfasten the screws on the back that hold the casing cover to the chassis. This will expose the enternal components, then all you simply need to do, is find the lightbulb, unclip this from the holder and then replace it with one of the same make and model. Fitting and re-assembly is as straightforward as it is taking the unit to bits.
go to http://www.google.com and type in GE Microwave lightbulb........this will get you the details about the bulb, and use the same google search to get your service sheet/ disassembly guide. Easy as 1,2,3.
Hope this works for you and please contact me here if you need further assistance in this or any other matter that is of a technical nature.
Yours sincerely
Oz
14helpful
7answers
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! [email protected]
1helpful
2answers
Lamp relacement
If you could post the brand and model, we can give you more targeted help.
3answers
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
