SOURCE: I deactivated my faceboook because it had a wrong number
how do i reactivte my facebook account
SOURCE: have deactivated mouse on acer5520G how do i reactivate it
Support Solutions from Acer:
Product
Notebook Acer Aspire 5520 G
Issue
Mouse / Touchpad not working
Solution
If the mouse/touchpad is not working, ensure that it is turned on. Press and hold the blue "Fn" key located in the lower left hand corner of the keyboard. and tap the "F7" key one time.
Fn-F7
A message should flash across the bottom center of the screen stating "touchpad enabled".
If this does not address the issue, the notebook may need service.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: my jitter bug phone is
To start, we do not recommend removing the battery from a phone that is frozen while on. This can cause a short in the phone and do further damage. This should only be performed if you are instructed to do so while speaking with a customer service or technical support agent.
For an issue like this, the first thing we recommend is to try and turn off the phone, but it sounds like you have already tried this so I would recommend calling our Customer Service department for further troubleshooting. We can be reached (800) 733-6632 24 hours a day, 7 days a week.
I can tell you that two common causes of phones freezing are being an area with low service and unplugging the wall charger from a wall socket while the phone remains attached to the charger. It is always best to either plug in or unplug the wall charger from a socket when the phone is not attached.
SOURCE: How do I block a phone number on jitter bug
push on number for 5 seconds till a pop up shows that says block number,press that
