Hotpoint wmef 742 washing machine not heating up
Is there a overload switch I could check .
    Top Expert:
  • Audio Player... Master
  • 66,248 Answers
CHECK HOT WATER INLET HOSE .
Posted on Nov 24, 2019
6ya staff
SOURCE:
Anonymous
  • 1028 Answers
SOURCE: how do i check the filter on a hotpoint washing machine
no filter but pump may be plugged remove front panel pump om right side ..to remove panel putty knife press hidden clips under front edge and pull panel forward
Posted on May 29, 2008
JULIANFIX
ALBERT GARCIA
  • 975 Answers
SOURCE: hotpoint aquarius wm62 - cycle stopped
theres two type of switches , the magnetic and the standard switch with the little hook , you need a multi meter tester , set meter to OHM and check the two leads that connects to the switch, while the tester is connected close and open switch , if meter reads 0 then switch is bad.
try to clean switch with a TUNER CLEANER by RADIO SHACK and try again . hope this helps AJ
Posted on Dec 09, 2008
Anonymous
  • 24 Answers
SOURCE: Hotpoint WF840P washing machine
the pump is blocked... at the bottom back there is a plastic cover, remove this and the pump is located on the back right hand side.
tilt washer far forward, place a bucket under to catch water and remove pipes.
once cleared, test again, if still no joy then you just need a new pump, but this part is a work horse so i would assume it is blocked with something like a baby wipe or babies sock (usual suspects)
Posted on Apr 18, 2009
Anonymous
SOURCE: My hotpoint wf860 washing machine has no power!
hi guys
Posted on Jun 16, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: My kenmore he washing machine was overloaded and
Remove the bottom front access panel,reach up inside on the latch side and feel for the pull ring.
Pull it to open the door.
Clean out the drain filter while you have the panel off.
Replace the door latch wax motor.
Posted on Mar 02, 2010
How do i fix my washer ?
Please check if the machine is not overloaded and causing the door to not close fully.
If that is not the case, try blowing air into the door switch, sometimes a little something can be stuck there.
if not, the door switch is faulty, have it replaced with local service center.
Feb 22, 2015 | Hotpoint Washing Machines
Wash cycle selector knob just keeps going around
sounds like a mechanical defect. Anyway, I think you need to invite a technician.
Jul 16, 2014 | Hotpoint Washing Machines
Washing machine not heating
PLEASE CHECK THE WATER COMING TO THE FRONT WASH FRONT LOAD WASHER DONT HEAT THE WATER IT AS A HOT AND COLD WATER VALVE CHECK WATER VALVE
May 02, 2014 | Hotpoint WMA50 Front Load Washer
Washer will not spin it start to but barley moves
my hotpoint wmpf-742 machine,been told bearings have gone,just need to know,if it has a sealed back,if it has,also been told to scrap it??
Jan 19, 2014 | Hotpoint Ariston AW125 Washer
The hotpoint washer has just started making severe banging noises on the final spin.
Take the lid off and check that the counterweight is tight and the both springs are ok. Then tilt machine back and check both piston supports are connected. If all looks good then the machine is most likely overloaded. Hope this helps
Mar 02, 2011 | Hotpoint Washing Machines
Hotpoint dryer nvl333eyoww, Motor runs, heating
Did you ohm out the thermal overload?
May 18, 2009 | Hotpoint Dryers
Beko wma512w front loader
CHECK THE CONTROL CARD FOR DAMAGE OVERLOADING THE MACHINE CAUSES THE CARD TO OVER HEAT.AND MELTS THE SOLDER ON SOME JOINTS.HOPE THIS HELPS
Dec 03, 2007 | Hotpoint First Edition WMA22 Front Load...
32 people viewed this question
Ekse
 Grubhead
Grubhead
