C 2 error code mentioned for what? in blustar vrf ac
    Top Expert:
  • Office Equip... Master
  • 66,126 Answers
ASK GOOGLE
Posted on Nov 24, 2019
3 Suggested Answers
6ya staff
SOURCE:
lpfaff1
L Pfaff
  • 11573 Answers
SOURCE: Lg vrf error code ch 79
Error codes below
https://www.lgklimaat.nl/Sitefiles/downloads/LG%20Checkpoint-%20codes/LGCheckpointcodes.pdf
Posted on Jan 27, 2016
ray gallant
  • 66126 Answers
SOURCE: Lp hp cf error showinng in my 11ton blustar ac
call an AC repairman .
Posted on Jul 01, 2016
My Peogeot 206 HDI has a diagnostic error code P14660. The engine turns but it doesn't start
that fault code is too high for a Peugeot 206 with OBD2
i checked all the Peugeot car forum sites for answers
on that code
P14660 no mention
PO4660 no mention
PO1466 no mention
need to start back old school diagnosis
fuel pump ... spark at plugs
this is the world list of all PO obd2 fault codes
http://www.troublecodes.net/pcodes
Oct 26, 2016 | Cars & Trucks
Peugeot 206 error code p14660
on that code
P14660 no mention
PO4660 no mention
PO1466 no mention
Oct 26, 2016 | Peugeot Cars & Trucks
Toshiba washing machine When I push on the error E7-4 shows and then it turns off what is E7-4 error ?
Is your machine either the Toshiba AW-SD120SM or AW-SD120SS?
If it is I checked the manual and the error code you mentioned is not listed in their operators manual. On page 35 of the manual there is a message that says "As for information display beyond the above-mentioned details, or the above-mentioned solutions do not work, please disconnect the power plug and contact technicians for repair."
The only codes mentioned are: E1 E21 E23 E31 E32 E5 A ans F
Jul 31, 2016 | Washing Machines
Gree air conditiones H4 error code
Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
Apr 30, 2014 | Heating & Cooling
Riso 390U error code p19 208 .... doesnt seem to be loading the master roll correctly, any suggestions?
Error P19-208
Error type P19: Thermal-pressure motor lock Error point 208: TPH pressure sensor does not go ON within 2 seconds after the thermal-pressure motor activates in the decompressing direction.
Hints: Check mentioned sensor. Check mentioned motor.
Jan 06, 2011 | Riso RZ220 Duplicator
Error code H101 and also P18531. Lights are flashing. Will not go.
Error H01: Ink color setting error Cannot get consumables info inut values required. Enter the required parameter value. (1: black / 2: color)
Error P18-531: Type P18: Drum-lock-solenoid lock. Point 531: Print dum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated. Hints: Check mentioned sensor. Check mentioned solenoid.
Sep 13, 2010 | Riso RZ390 Duplicator
Error code p-12 316
Error P12-316 means:
Type: P12 - Master-disposal-section motor lock. Point: 316 - Master-compression-motor encoder sensor count did not change within 10 milliseconds after the master compression motor activated.
Aug 24, 2010 | Riso RZ390 Duplicator
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
Lexmark x4270 error code#1203 want print
Please visit this below mentioned link to solve your problem:
Error Code 1203
Thank you
Dec 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
All-in-one printer. can't turn it on
You have mentioned Hp printers but can you mention model number .
Also mention the problem or any error codes faced by you .
Oct 29, 2008 | HP Office Equipment & Supplies
jasbo
jasbo
Ekse
Marvin
Marvin
