SOURCE: 9v battery wires came loose. peavey 5 string bass
The negative battery terminal will go to a black wire and that will be soldered to one of the volume control cases. That makes the remaining wire easy. The negative terminal pole on the battery is the larger round one.
SOURCE: volume control of peavey bass guitars
Sorry but your post did not provide enough info. Are you having a problem with the volume control. Do you need a wiring diagram. What model Peavey bass do you have. For instance, the Peavey bass I have has active electronics ans requires a 9 volt transistor radio battery to power them.
SOURCE: peavey decade manual
Recommend an Ashdown or Fender with a 15" speaker, they will give a good sound, are gig-worthy, and will last. I use a Behringher 120W for rehearsal work, it only has a 12" speaker and thus cannot give a good 'presence', also I have been reliably informed, a lot of custom chips are used in thier amps.
Don't forget, a bass 'E' goes down to something like 60Hz, and a good speaker and amp are a must for bass work
Testimonial: "Thanks for the recommendations. I will keep them in mind."
SOURCE: What year is my peavey bass guitar serial number 03893053
According to this
https://en.wikipedia.org/wiki/List_of_Peavey_guitars#Bass_guitars
it is a 1989 model. It was a very good year.
Jon has told you about the serial number.
Don't get Fender Fenders confused with Squier Fenders either.
Once you know the serial number you should be able to find out the year here
http://www.guitardaterproject.org/fender.aspx
Then you could try Googling:
"reverb.com Fender Jazz Bass (year)"
and you will see a range of used prices.
This is from the Peavey website. It indicates a date between 2001-2003. I found a date from another source indicating 2003. They Fury IV is a nice instrument!
"Offset double cutaway solid body, 21-frets, Quilted Maple top, solid maple neck with rosewood fingerboard, two VFL internally-active pickups, 3-band active EQ, single master volume, mid, bass, and treble controls, satin chrome hardware, available in Trans. Red, Trans. Blue, Trans. Green, or Sunburst finish, 34 in. scale, mfg. 2001-2003"
There is further info available from Peavey: http://www.bluebookofguitarvalues.com/Electric_Guitar_Values/Manufacturers/PEAVEY/Categories/ELECTRIC_BASS__FURY_SERIES/Models/FURY_4_QUILT_TOP?id=PEAVEY_ELECTRIC_BASS_FURY_SERIES_FURY_4_QUILT_TOP
