The cycle has finished. End has come up on the screen. Red Door Lock button turns off. The machine clicks off, but the door will not open.
Door assembly needs replacing, can open door using old credit card/drivers licence, sliding between cabinet and door(toward centre area of handle-behind it), pushing the door lock in left hand direction, you can remove the items from machine.
Very likely your door latch has a problem. How it works is when a program is in progress, a signal from the motor inhibbits the door from opening. only when the final spin is completed will the signal be given to open. Briefly switch power off for about 10 seconds then awitch on and re try to open door. If no luck, switsh off power and take kick panel off at bottom front of washer..Normally there is a flat ribbon type pull cord that will allow the door to open when pulled.Once opened, reclose securely and retry"open door button"after this it gets a little technical and testing equipt. is needed.
