SOURCE: my LG front load washer won't spin! Has code OE or
Check the door lid switch. Maybe it's not closing good. Try to stick a screwdriver in the switch.
Thanks
SOURCE: lg wm-2277hw front load washer getting a OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: my lg front loader steam washer is not draining
SOURCE: LG front load washer OE error. cleaned filter need
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
SOURCE: My LG front load washer WM1812 CW will not pump
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation - but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG has some information on this error code..
Hello & Welcome to FixYa
Correct, OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter located inside the bottom front panel for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
