SOURCE: power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
SOURCE: Had power outage and now
no! did the porew surge when it came back on,like the lites in the house went briter than normal/may have damaged main control board in top console.you will also fine a tech sheet up there.see if you can get some glues their.God bless.tom
SOURCE: My E-machine W5243 system will not power up.
have you tried another outlet or another device in the same outlet? If you have then you might be looking at replacing the power supply.
