SOURCE: I can`t switch on my g-hanz TV
http://resources.jvc.com/Resources/00/00/94/YA059ien.pdf This is a link to a pdf copy of the owners manual for your model television. You can find all the setting and function controls listed in the manual. To reset the television to factory settings, you must unplug it from the a/c power source for about thirty minutes. This will reset the television to the factory settings. You can do the same thing with the remote control. Just remove the batteries and press the input button continuously for about 1 minute. This will drain all the power out of the microprocessor and reset the remote control to the factory settings. You can then use the owners manuals to reset the television and remote functions.On turning on the television the interactive plug in menu will appear. From here you can set the language you want to use for the television. All of this is explained in the owners manual.You will need a pdf reader and writer to read the owners manual and the writer to make a copy for your own use. I hope this information helps you with your problems with the remote control and television. Thank you for using FixYa and have a nice day!
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
To unlock it, you must have its remote control
SOURCE: How do i get universal remote to work for g hanz beatrix? No other remote. Tv on child lock.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
