SOURCE: how can i remove the
We have had the same problem. Here is a solution that has worked.
Turn on the dishwasher with detergent as usual. After the initial drain and fill, stop machine open door and add about 2 cups of white vinegar. Close door and let machine continue cycle. I think you will find that it removes "bloom" on glassware and on the interior of the machine. The trick is to not cancell the cycle but to continue it with the vinegar so that the heat can help the process. J.
SOURCE: sony KDFE42A10 bloom in middle of picture
I have the KDF-E42A10 and my co-worker has the 50". Similar problem started in early September and it is definitely the optical block, which is due to a faulty manufacturing design flaw. Spoke with half a dozen people at Sony, including their National Customer Relations Customer Information Services Center and all have the same response that "they understand it is an issue but they are unable to accommodate since our models are not part of the extended coverage list". Basically they do not have enough complaints to justify adding our models. So anyone with a 2005 model I suggest you write a letter to these two addresses and voice your concerns, issues, and complaints. They do review these on a quarterly basis and if they do notice an increase they may consider encompassing our models. Unfortunately in the in meantime you may have to pay for the repairs out of pocket but hopefully when they finally include us we will seek reimbursement.
Sony Electronics
Attn: Executive Review Committee
12451 Gateway Blvd
Fort Myers, FL 33913
Sir Howard Stringer
Chairman & Chief Executive Officer
Sony Corporation
550 Madison Avenue
New York, NY 10022
SOURCE: where can i get contact details for chico
It depends on whether you are in the US or UK.
The UK contact info is as follows:
Chicco U.K. Ltd
Prospect Close
M. Lowmoor Road
Industrial Estate
KIRKBY IN ASHFIELD (NOTTINGHAMSHIRE NG. 17 7 LF)
(0044) 1623-750870
(0044) 1623-723880 (fax)
The US contact information is:
Chicco USA, Inc.
Attention: Customer Service
1826 William Penn Way
Lancaster, PA 17601
1-877-4CHICCO (244226)
Customer Service Option: 6
[email protected]
Mon – Fri, 8 am – 5 pm est
If you are not in the US or UK please let me know as I have contact info for other locations as well.
SOURCE: Bloom speakers only emit very low sound after being connected
well i dont know what to do except turn your volume on really high and make sure its plugged in. no they dont need batteries; i got mine today and its not that quiet its blue and i think its okay. but i dont know if its that bad you should return it. mine was only 7 bucks
SOURCE: how do I make the blooming flash work?
on the left side of the camera there should be the usb port and theres a little switch right above it,, if u push it down it will put the camera in "normal" mode and the flash will come on automatically.. if not u might have to do it manually by pressing the lightning bolt button
