SOURCE: Dave delivered 52 newspapers in all. Saturday and
He delivered on Saturday 22 Newspapers and 30 newspapers on Sunday. Ok Wiz Kid.
SOURCE: 24cc craftsman 2 stoke
Low side adjustment on the carb needs to be opened up or the carb needs to be overhauled. To open up the low sie, find the carb jet adjustment screws. The screw closest to the cylinder is the low side. Turn the screw counter-clockwise 1/2 turn. You may need to romove tho plastic locks from the adjustment screws, or if it is fairly new, you may need to buy a special tool to use on these screws. The tool is available anywhere that sells Poulan parts. If adjusting the screws doesm't fix it, the carb will need to be overhauled or replaced. Check with www.searspartsdirect.com . Replacement carbs are sometimes cheaper than an overhaul.
SOURCE: I have no flight confirmation number for a return
Go to the site through which you booked and see if the ticket was actually booked.
