Question about Brother Sewing Machines
I have a Brother VX-1120sewing machine and when I start to sew the lower thread is all tangled and a lot of it but the top looks perfect
    Habit-Forming:
    New Friend:
  • 153 Answers
Hi Beth-
I found this link.
https://help.brother-usa.com/app/answers/list/st/5/kw/threading%20problems/p/6530/page/1
I also found this youtube video link regarding the Brother VX1120. Highlight the link, right-click and "Go to https://video.search..."
https://video.search.yahoo.com/search/video;_ylt=AwrC5pnD.u9dBFIAJMz7w8QF;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZAN3cFhDTXpFd0xqRXlpaEVKWGFfVmpnTERNVGd4TGdBQUFBQU1GbjE3BGZyA3lmcC10LXMEZnIyA3NhLWdwBGdwcmlkA0RWcWI3aVE5U0VxUWRwa3VFMDFLU0EEbl9yc2x0AzYwBG5fc3VnZwM2BG9yaWdpbgN2aWRlby5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzM1BHF1ZXJ5A2Jyb3RoZXIlMjB2eDExMjAlMjBzZXdpbmclMjBtYWNoaW5lBHRfc3RtcAMxNTc2MDA4NzEy?p=brother+vx1120+sewing+machine&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t-s
Hope these help.
Posted on Dec 10, 2019
6ya staff
SOURCE:
Anonymous
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
Anonymous
  • 323 Answers
SOURCE: Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
Posted on Jun 18, 2008
David Robinson
  • 140 Answers
SOURCE: threading problem on Singer Sewing machine Inspiration 4206
This can be caused by incorrect bobbin tension or the bobbin is in backwards. Take out the bobbin and put it in according to the instructions for your Singer. If you still have the same problem try tightening the bobbin tension. Please ask if you have any questions.
Posted on Dec 30, 2008
Anonymous
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
johntrev800
SOURCE: brother vx-950 sewing machine
Place thread spool on the spool pin at back right top of machine. From there, thread through 1) rear thread guide (little hook), 2) front thread guide (front hook), 3) down and up through the thread tension dial from right to left so that thread picks up the thread spring check (the little spring on the left of the tension dial). 4) Through the thread take-up-lever, from right to left (the little lever that goes up and down). 5) Through the thread guard and guides (one on the front, one on the needle arm). 6) Through the needle, front to back. Good luck johntrev800 (at) yahoo.com
Posted on Jan 19, 2009
Stitch issues
Find the tensions on your machine. Usually a screw below on the bobbin regulates the top stitches tension. Usually a numbered wheel on top--where the thread is around it--regulates the bottom stitches. YOU NEED TO ADJUST THE TOP WHEEL, test on scrap material, and if looser, you are in the right direction. If it is still a mess. turn the knob to a lower number.
Apr 04, 2014 | Brother CS6000i Computerized Sewing...
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
Why is my brother sewing machince lower thread tangle
try changing the needle
try a different bobbin
make sure the bobbin is wound correctly and not over wound
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
make sure the top thread has not come off the thread take up lever
Nov 29, 2012 | Brother Sewing Machines
I had sewing machines E6 computer bother a few yeas . Now I sewing , it turn E6 . what does E6 mean? Can you help me . How to fix it? Thank you.
Download a free manual from www.brother-usa.com and under support and put in your model number. E6, means that the thread is tangled, totally unthread it, now with the presser foot up, rethread, pull the top thread, now lower the presser foot and pull the thread, it should barely move. This will seat the thread in the tension discs. Read your manual before using, it will save you lots of grief. People love to skip this step, and wonder why the machine is not working right. This is one time you should take the time, it is worth it.
Apr 11, 2011 | Brother CS-6000
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
The lower thread is getting tangled. I have changed the bobbin, re-wound the bobbin thread again, taken the bobbin out and cleaned the bobbin case.
Incorrect threading of the top thread can also cause lower loop tension problems. As can the wrong size or blunt needle. Try re-threading top thread first.
Dec 21, 2010 | Brother Sewing Machines
The stitches are really tight
If you can't adjust the bobbin tension, adjust the top tension. Also the lower thread needs to be pulled to your left (away from presser foot) before you start sewing, this avoids tangles.
Jul 04, 2010 | Necchi 3537 Mechanical Sewing Machine
Thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
May 30, 2010 | Brother XL-3510 Mechanical Sewing Machine
Lower thread problem
are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Sep 14, 2008 | Brother XL-6562 Mechanical Sewing Machine
Sewing Machines Logo
44 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
