But it always say that i can play it with out error codes or cleaning the disc and it is very stupied to do that all rhe time
SOURCE: it wont download mario kart
Hi.
This code meens that you wiishop channel is having troubles connecting properly to nintendo servers.
Since you´ve got this error code your using the wireless connection, right.
Try moving the wii closer to you access poit (ADSL modem, router etc.)
That might help..
SOURCE: new disks won't work, wii doesn't read
If Wii gives Disc Read Error, first step you need to check is totry another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
SOURCE: New wii for xmas already broke in February-disc
I think the [roblem comes from game usege and bad care. Another thing could be where you bye the games. The same thing happened to me but I found a solution that will not work with you.
SOURCE: Error message when loading Mario Kart in DS
it is corrupted whish means it wont work any more srry it happene to near enough everyone
