Contact Sears for assistance. Online web site did not show that model, so you may need for assistance if model is no longer available.
https://www.searspartsdirect.com/search?q=630-12902312
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console. It is a small silver colored device
attached to a white plactic bracket. In some model dishwashers the
wrong gage wiring was used causing the wires to heat up and trip the
thermal fuse. There was no apparent risk of fire or anything like that,
but the thermal fuses didn't tolerate the heat differential too well. A
fix for the problem was to purchase a thermal fuse replacement kit
(found at most appliance repair stores) that had thicker wires. The
part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at
repairclinic.com. Order on line and have the part shipped directly to
you. Now...to access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even
though the dishwasher is not running, the control board still has live
voltages present.
2. Open dishwasher door and remove the top screws that hold the console
in place. You shouldn't have to remove the lower screws unless you plan
on removing the entire door panel.
3. The control panel should pull off from the front enough to where you
can access the control board. There is a thermal fuse mounted on the
board with two wire leads going to it. The fuse is silver in color and
mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it.
Leave plenty of wire to accommodate. There will be instructions included
with your replacement kit. Ensure you follow the direction thoroughly
and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging
the old fuse and replacing it with the new one (been there). The fuse
will eventually blow again. Follow the instructions provided and you
can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop and they SHOULD have the part available. This is a known problem and a common fail item.
SOURCE: Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
SOURCE: Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
SOURCE: how do I acess the control panel
Open the door and remove the top screws connected to the console. Close the door (not locked) and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
SOURCE: how do i test a thermal fuse
A fuse is tested using the continuity or resistance (ohm) setting on a multimeter.
Disconnect the power to the dryer. Disconnect the leads to the fuse. With the meter set on continuity, the meter should beep - if you set to ohms, you should read 0 ohms across the terminals of the fuse. If you read infinity, the fuse is bad.
