Question about Sony Audio Players & Recorders
What are the codes to program a SONY (DAV-HDX975WF) 5 disc player to a BELL (5.4 IR , 187017) REMOTE ? , Thanks , Jason
    Top Expert:
  • Sony Master
  • 55,370 Answers
You have this backwards. Applicable code(s) will be found in the remote control, if it is compatible.
Posted on Nov 28, 2019
6ya staff
SOURCE:
Lapete
SOURCE: Universal remote code
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotehome.shtml
Code 720# for my 26" insignia tv on me bell remote 3.2 IR - 137181 and it worked for me. Click on link choose the type of remote you have.
Good luck
Lapete
Posted on Mar 23, 2008
Anonymous
SOURCE: Program bell expressvu remote for new tv
The easiest way is to do device code scan. Since you want to program the TV, hold the TV button on your bell expressvu remote. When all the top buttons light up, press the power button, the TV button light should remain lit. Keep pressing up/down until your TV turns off. When your TV turns off, press the # button. Thats all. Your done.
If you want to set up the AUX button, hold the AUX button until all the buttons light up. Then press * and either
0 - second TV
1 - second VCR/DVD player
2 - audio amplifier or cable box
Then press the power button and press up/down until the device turns off. The last step is to press # and your done.
Posted on Feb 05, 2009
Anonymous
SOURCE: Cannot program tv using bell satellite remote
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Posted on Apr 01, 2009
Anonymous
SOURCE: Comcast Custom DVR 3 Device code for Sony DAV-X1
You can find the codes in the manual at this url: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Apr 07, 2009
Anonymous
SOURCE: Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Posted on Apr 28, 2009
Why can I not program a universal remote(1056B01-L) to work with BDP-S470 Sony Blu-ray Disc/DVD Player?
I have an IR 20.0 remote and non of these codes work. Is the remote just too old?
Jan 21, 2012 | Televison & Video
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
Cannot find code for universal remotes to make Sony DAV-C450 work
To repair your original remote, open the remote and remove the buttons sectio.(normally a solid piece of rubber with the buttons) On the PC board of the remote, clean with a scotchbrite scourer to revive the circuits and make it shiny. Next, clean the rubber button section on the inside with surgical spirits. Replace cover and fit new batteries.
Jul 12, 2010 | Sony DAV-C450 System
Need 5-digit code for universal remote on DAV-X1
There may be no code in the library of your Insight remote. You may have to try a different universal remote.
Apr 04, 2017 | Sony DAV-X1 System
Jan 25, 2009 | Durabrand HT-3915 System
Need code to program Comcast Universal Remote to our Sony DAV FR9
First you need a Comcast remote with the center button, OK/Select to be grey. Now program in code 1903 to aux. Works on my FR8 System, same basic as FR9. I was unable to get Comcast remote with red center, OK/Select, to work with any codes.
Dec 31, 2008 | Sony DAV-FR9 System
Need a universal remote control code for sony dav-dz 100
1903 will work for most functions, but not the DVD player buttons.
Nov 03, 2007 | Sony DAV-X1 System
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
