Question about Samsung Televison & Video
I can't get picture on Samsung smart TV. did see picture with the flashlight test, was able to change to menu. think sound worked. now it seems to turn itself off after a few seconds.
Samsung LED model UN60J6200AFXZA Smart TV. Should I replace the 'main board' It has only two boards inside.
    Top Expert:
  • Samsung Master
  • 55,370 Answers
Probably a failing power supply
Posted on Dec 07, 2019
6ya staff
SOURCE:
SOURCE: Samsung LCD TV Model LN46A550P3FXZA sound is cutting in & out 1-2 second intervals
Your video and audio (sound) signals are generated on the main board. However, for those circuits to work properly, they have to have clean and accurate power from the power supply board. The power supply boards are notorious for bad capacitors. Has your power supply been recapped? Do you see any bulging tops of any of the capacitors? If you are not familiar with capacitors, just google bulging capacitors. There are plenty of pictures on the web to show you what they look like. It is possible that the main you have has a problem. I assume you order the same exact part #?
Posted on Nov 12, 2013
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: I have audio but. No video on my vizio model e47oiao I've seen where there is a led board but my tv only has power supply board and main board using a.flashlight I can see the menu board any ideas
if you dont have any clue,take it to someone that does or damage your tv
Posted on Mar 26, 2015
Sp Gupta
  • 727 Answers
SOURCE: I have a broken Samsung UN60FH6003FXZA . Has sound but no picture. Did flashlight test & can see menu options. Suspected the power board/ LED driver is bad. Replaced board and the problem continues
Hi Jorge,
It appears to be the backlight problem and it is common with almost all the brands. Some of the LEDs in the backlight array fail or burn and cause this problem. Replacing these LEDs solves the problem, but it is a delicate and risky job.The panel has to be opened for this and only an experience technician must do it.
Here in India we do it regularly.
Good Luck.
Posted on Aug 10, 2016
gopakumarg43
  • 76204 Answers
SOURCE: how can I fix Samsung LED Smart TV UA48J6300AKXXA?
If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure, and memory initialization of many popular brand TVs and other devices are given in detail.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 23, 2016
Testimonial: "than you"
emissionwiz
Marvin
  • 85222 Answers
SOURCE: Samsung UN50H6350AF LED TV. No picture. I do get backlights and sound. (See pic) I tried replacing the main board and the T-con board and there was no change. Any suggestions? Try power supply board?
You have wasted enough money guessing bite the bullet and replace the TV. I have done this same thing and regret it to this day, should have just junked it.
Posted on Dec 02, 2016
No Picture No Image & Blank Black Screen Samsung Model: UN55ES7100F Model Code: UN55ES7100FXZA Version #: US02 Serial #: Z5HP3CACC07708W.
I think your on the right path, start with the tcon board, could be the main as well but the tcon is way cheaper so start with that
Mar 13, 2018 | Televison & Video
Network issues with Samsung Smart TV UN60JU6500FXZA
You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
Since you can access your network when hard wired your network password is stored.
Once you have verified Smart Hub is functional then work on WiFi.
i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
I use Bluetooth access to share photos from IPads.
I would leave TV hard wired.
Sep 20, 2016 | Samsung Televison & Video
I have a Samsung UN50H5203 LED smart tv that has sound, but no picture.
I wouldn't replace a power board before measuring to see if the voltages are there and correct....
Sep 08, 2016 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
Samsung TV
If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
Aug 07, 2016 | Samsung Televison & Video
My 50in hisense smart tv has sound but no picture can it be repaired
I've got same problem. I did a flashlight test and found out my backlight is not working right. Think the tcon board will fix but not 100% sure.
Feb 19, 2016 | Hisense Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
How do I fix my Samsung 40 LED TV that has sound but no picture?
When repairing LED TV Back light assembly you need to contact expert person because lifting of LCD TV panel is very dangerous for non technical person. Be careful
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Televison & Video Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
