Being a new HP printer user, you might want to ask, 'how do I find the WPS Pin on the HP printer for configuration?' Well, here are the right steps to locate the WPS Pin. After turning on your printer, navigate to the screen of your control panel and click on the Settings. Now, tap on the Wireless button and then click on the Wi-Fi Protected Setup. Follow the on-screen prompts carefully and tap on the WPS PIN option. Your WPS Pin will now appear on the screen of your HP printer. After locating the pin, you can proceed to connect your printer using WPS Pin. https://connectmyprinter.com/how-to-find-wps-pin-hp-printer/
You don't. Printers only print what the computer (or smartphone app) tells it to print, The dollar sign is above the number 4 and is accessed by pressing Shift+4 = $
The WPS "key" , not PIN, is on a label on your router. Not on your printer.
Use that for setting up your printer. If you're leaching off a neighbors wifi system, you're out of luck.
It relies on the WPS button on your router. Get to the Searching for WiFi on the printer then push WPS button on router. After a little delay the printer should say it has connected to network. If not, use the function that connects via the router password entered directly.
Good luck and please rate 4 stars if answer is helpful.
I believe that Justus answer is incorrect and looks to be AI Produced. The SSID WPS PIN number is on the Router not on the printer. You tell the router to search for the printer, and you tell the printer to look for the Router. When they find each other, the Printer will ask you to enter the SSID and WPS Password that is on the Router. This is the way I did my Canon MG7120 to a Bell Home Hub Router. The process is the same setting up my iPhones for WiFi.
Go to the menu button on the printer (choose the option above "OK" button), choose "Network" (Get this option by keep pressing the Menu button until the "Network" option is shown and hit "OK")--"Network Configuration"--"Print". Page #2 of the printout will shown the WPS pin number of your printer. There are two WPS serial numbers shown, but the one on the bottom called "WPS-Pin for NFC" worked for me.
dear lydia the scanner is jammed.you may try with knocking lightly on your both palm at the top of platen cover. some time this releases the jam. if persists call trained person to re assembly the set. thanks.
