Question about Toro Garden
I have a Toro zero turn. My steering handles are a little loose and hit and/or overlap in the middle. How do I adjust this? I found instruction for lowering and raising but nothing more.
  • Toro Master
  • 2,016 Answers
Tighten the arm pivot bolt. Visit WWW.TORO.COM and navigate to "parts and manuals", enter your model number, select model, and further navigate to parts diagrams.
If you cant find the diagrams, comment here and I'll post a copy of steering arm diagram.
Posted on Nov 21, 2019
    Habit-Forming:
    New Friend:
  • 153 Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Posted on May 18, 2008
Anonymous
  • 226 Answers
SOURCE: the steering wheel on my toro lawn tractor is
no; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Posted on Jul 29, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: It's extremely hard to turn the handle to raise
Bosch has a technical bulletin to address this problem, it requires the adding of shim washers under the gear and above the hex nut. If you are still having a problem let me know and I will get part numbers for you.
Posted on Aug 20, 2009
Anonymous
SOURCE: sub zero door handle is loose
5/16 hex bolt nut driver
Posted on Aug 29, 2009
bigboikc79
SOURCE: The steering levers quit working on my zero turn
My steering levers on my zero turn toro quite working, The mower wont go forward or in reverse any ideas on how to fix this.
Posted on May 24, 2011
Mx5050 toro zero turn mower, one drive arm more dominant than the other. With both arms all the way forward the mower slightly turns to the left. Any adjustments to correct this issue?
1st with mover off verify that both handles move same amount forward , I use a string to measure them , they both have mechanical stops that do bend and move sometimes
second locate control body valve , (thing that handles connect too) there should be a pump pressure adjust (allen key) on the side of this your gonna need to make small adjustments and try it , is difficult to do if you don't have a lift to elevate wheels of mower (but is possible without ) but takes patience
Apr 25, 2015 | Toro Garden
Toro instructions
un hook them they maybe dirty and rust causeing no release
Sep 01, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
When I go forward the handles are not even, pulls to the right
there should be a adjustment on the linkage or a stop for each handle
Apr 21, 2012 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
What bolts do i tighten on the steering? Went to a tire shop and they said that it is loose.
depends on the make and model of your vehicle. in general (most vehicles) there is an adjustment on the steering box. look for a large nute with an allen head set screw in the middle of it, place an allen head wrench on the adjustment screw to ensure it doesnt move and break the set nut free, turn the adjustment screw down one half of a turn and re tighten the set nut. go test drive you car around the block, repeat as necessary. me sure not to over tight/over adjust your steering box, this will cause your car to handle dangerously ans easily loose control. if this process doesnt cure the issue check for a worn rag join and universal joint on the steering pillar. also check for worn out bushings, pitman arms, drag links, track bars and tie rod ends
Mar 15, 2012 | Cars & Trucks
Engine will stall when levers are moved from park position to center unlock position.
You didn't mention if the same thing happens engauging the mower deck. If it does both, start with the carb and choke. also, check out the safety switch on the steering handles for a loose wire or a ground short. This should be fairly easy.
Jul 09, 2011 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
The steering levers quit working on my zero turn Toro Timecutter 16-44.
Jun 12, 2010 | Garden
Go in reverse
The steering levers control all movement on a zero-turn mower. Just slowly pull both handles back evenly and you'll go backwards in a straight line. The farther you pull back the levers the faster it goes backwards.
May 17, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
New craftsman, pull chord will only pull 6 inches
check the brake cable that goes to the flywheel, you may have something loose or broken. the lever on the handle you press to crank it may have come loose from the cable. it may be loose at the end under the cover also. some have adjustments some don't.
Jul 13, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
