Question about Sony Audio Players & Recorders
How do I reset my Sony STR-D790 display screen?
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 71 Answers
SOURCE: sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Posted on Mar 15, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: how to hard reset a sony str-DE898
I couldn't find anything about a Lock Code in the manual but here's the general setting-reset procedure:
Turn OFF the receiver
Hold down the I/0 for 5 seconds - "PUSH ENTER" appears on the display
Press ENTER
Posted on May 17, 2009
Anonymous
  • 94 Answers
SOURCE: sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Posted on Sep 22, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Sony STR-D665 receiver display flashes "PROTECT"
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 07, 2010
No display can you help
If the display turns on when you push on the front panel, then you most likely have bad solder connections on the display tube. These will need to be re-soldered.
Dec 29, 2015 | Sony STR-D790
My sony str-de845 has an error
First I would try to reset it. With it off, hold the power button for about 5-10 seconds. It should either reset, or tell you to press enter to reset it.
Apr 26, 2013 | Sony STR-DE845 Receiver
Sony STR-DE375
there are a number of possibilities, bad solder connections on the display board, missing B+, a defective driver display ic, this is a situation a diagram would be helpfull.
Mar 10, 2012 | Sony STR-DE375 Receiver
How do u reset soney reciver str-dg510 i have no sound
What preceded this? Was it working and then stopped or did it never work?
http://www.retrevo.com/support/Sony-STR-DG510-Receivers-manual/id/2526ci754/t/2/
Page 26...
Press I/O to turn off the receiver
Hold down I/O for 5 seconds (("PUSH" and "ENTER" apear on the display alternately)
Press MEMORY/ENTER. After "CLEARING" apperas on the display for a while, "CLEARED" appears.
Jan 31, 2011 | Sony STR DG510 - AV receiver - 5.1 channel...
How to reset sony str-dg800 to factory settings
For the STR-DG800 you need to power off. Then hold power button 5 seconds. When "push entrer" appears on display push "memory/enter" button. System will turn off and reset.
Nov 17, 2010 | Sony STR-DG800 Receiver
Sony str db870 master reset
Sep 22, 2009 | Sony STR-DB870 Receiver
How to hard reset a sony str-DE898
Press ENTER
Apr 08, 2009 | Sony STR-DE898 Receiver
Sony str-de525 system "protector" problem
Mar 15, 2009 | Sony STR-DE935
Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Dec 28, 2008 | Sony STR-DA90ESG
Display
Protector appears on the screen
Nov 22, 2007 | Sony STR-DE715 Receiver
57 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
