Question about Shark Vacuums
I have a shark steam mop SV80N14. I haven't used it in 6 months as away and now the handle wont pump.. how do i fix that? Thank you
How do I make the pump on my steam mop SV780N14 work
    Diehard:
    Visited the website for 60 consecutive days.
  • 330 Answers
The tube behind the trigger is crimped shut. disassemble to fix the tube,
Posted on Nov 20, 2019
6ya staff
SOURCE:
satch498
satch franklin
SOURCE: shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
Anonymous
SOURCE: My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Posted on Oct 10, 2009
jgrieve647
  • 11 Answers
SOURCE: euro-pro Shark steam mop has a broken handle.
I have broken 4 shark handles, have repaired them its a pain. remove the screws on the handle end of the head pop out the broken handle part, drill a 3/16 hole into the part tap 1/4 inch threads use a countersunk head 1/4 inch bolt screw it together put epoxy on the inside to lock threads reassemble. its a pain. two small keepers lock the swivel together pry out with a screwdriver carefully dont loose them. I broke one shark handle when it was brand new. this repair works good if you like alot of fooling around
Posted on Mar 31, 2010
carebear1360
SOURCE: Shark steam mop won't steam
I have had my steam mop for about 2 yrs and absolutely love it. I have not experienced any difficulty with it until I recently noticed it would heat up but not steam.
I contacted Shark's Consumer Products services at 1-800-798-7398 and the person on the other end was very helpful. After giving me a few pointers, we discovered that my mop needs repairs.
They have a one year warranty, which my mop is past, so I will need to mail it in to them with a check for $9.95 for return shipping and a check for $17.95 for repairs. They will replace it if they are not able to repair it for no further costs.
I highly recommend giving them a call. There is also a live chat available on their website that can point you to the service or person you need to speak with.
Posted on Aug 06, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My shark steam mop will not start steaming. Are
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
f
Posted on Sep 25, 2010
Model sk410. how do I disassemble it?
Shark Steam & Spray Mop: How to Assemble - YouTube
? 1:27
https://www.youtube.com/watch?v=iH2NVXVA4-U
Sep 6, 2013 - Uploaded by Shark Cleaning
Assembling the Shark Steam & Spray Mop is easy. You'll ...Shark Steam & Spray Pro Mop: Using Steam and Spray Mode - Duration: 5:34. ... Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: 3:45.
Shark Steam & Spray Pro Mop: How to Assemble - YouTube
? 1:31
https://www.youtube.com/watch?v=I3thGlk2GdU
Assembling the Shark Steam & Spray Pro Mop is a breeze. ...Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: ...
Shark steam mop S3601 disassembly. - YouTube
? 3:38
https://www.youtube.com/watch?v=zq07GHhbJkI
Jan 07, 2016 | Shark Professional Steam and Spray Mop
My shark steam mop is farely new and all of a sudden just stopped working....i plug it in and it begins to slightly steam /heta up and then nothing even when i pump the handle...how do i fix this?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Jan 23, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Very little water comes out when handle compressed but no steam. what do I do? Machine is only about 6 months old and has been used maybe 4 or 5 times.
heatman101
Nov 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop is not producing steam when I pump the handle - twice the mop head has blown off when I tried to pump more than the usual allotted time. Any idea what is going on?
heatman101
Jul 05, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Have had my mop for 5 months love it and worked great I use 4 to 6 times a week but now it wont let out any steam
The element is gone and not replaceable...
heatman101
Jan 21, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Engonmic hand grip broke off
Check the manuals link and maybe they will replace it under warranty...
heatman101
Aug 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
29 people viewed this question
Top Shark Vacuums Experts
Del Backhouse
Level 1 Expert
brian kossman
Level 1 Expert
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
