Need to unlock my car stereo which is stuck on insert sd map so need to download the unlock software
SOURCE: WIRING DIAGRAM FOR 1988 TOYOTA PICKUP CAR STEREO
just use a volt meter and test around to find your powers and grounds. then look behind the speakers to find the wire colors and compare to behind the stereo
SOURCE: Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
SOURCE: Can't unlock maps on the SD card
I am still waiting for the promised free solution suggestions
SOURCE: HAVE NAV-CAM 7000 GPS....NEED UPDATED SD CARD W/SOFTWARE
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150362945965&ssPageName=STRK:MESELX:IT
