Question about Technics Audio Players & Recorders
Technics CD Player SL-CH530 disc not spinning.
The CD player worked fine when last used a couple of months ago. But when I insert a disc now and press the play button, Track 1 appears in the window then nothing happens and after a few moments I get a message "CD no disc". Is this something I (not an electronics person) can fix?
    Top Expert:
  • Technics Master
  • 66,248 Answers
SADLY NO YOU CAN NOT FIX IT
Posted on Nov 20, 2019
  • 1 more comment
  • Chris Humphreys
    Chris Humphreys Nov 20, 2019
    Is it fixable by an expert (if I can find one who does repairs to vintage equipment)?
  • ray gallant Nov 20, 2019
    THERE IN LIES YOUR PROBLEM VINTAGE
  • Chris Humphreys
    I take your point - thanks anyway.
6ya staff
SOURCE:
simplemitch
Mitch
  • 752 Answers
SOURCE: CD Player not playing any audio CDs
The laser is damaged or dirty. Try gently swabbing the lens with rubbing alcohol and drying with canned air. If this fails the laser is damaged and unrepairable.
Posted on Sep 12, 2007
Anonymous
SOURCE: Magnavox Jogproof Personal CD Player - says HOLD
there is a switch that locks all controls
Posted on Mar 01, 2009
SOURCE: Discs won't play.
please change laser unite then solve your problem
Posted on Sep 09, 2009
Anonymous
SOURCE: My Technics SL-DZ1200 will not play certain MP3
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Posted on Nov 12, 2009
roikkalampu
SOURCE: Technics SL PJ27
First I think you should turn your player on and wait 5 - 40 minutes before before you start liste3ning music.
because electrolytic capasitors may be little broken and those can repair themselves but it takes a while.
Good rule of thumb is that If you don't use every day an old device
then you should give to it every time a soft start . like I mentioned earlier
turn power on and wait.
Second try to play music cd which don't have any scratches and without any copyprotections
Third Disconnect power cable
Then open device and try to clean all dust.
Look for hairs and other difficult to see objects uselly
you find at least one hair inside old cd player.
If hair is around disk spindle it maybe difficult to
remove.
Check that cd-disk makes good contact so remove even tiniest dust and hairs
between cd-player and copact-disk. It may be called spindle or what ever but
still try to clean it with Isopropyl alcohol and remove dust and filth.
Check laserlens and is there some dryed liquid stains if there is try to remove those
with Isopropyl alcohol and swabs. Don't use any force and you can tear a top of swab little longer
(about one inch) and you get swabs which are much easier to use these kind of delicate cleanings.
Lubricate every moving part with lithiumgreese don't make any mess.
This last fix is for most desperate ones.
Connect the power cable and push eject and be carefull because
you can get fatal electric shock.
Disconect power cable. You can use extension cord which have on/off powerswitch.
You can see six tiny trim pots.
First take photo of those pots so you can undo all changes.
Change only one pot and only about 1/8 of turn. Turn power on and test if you make it worst or better.
If you think you fixed the problem that is not the case ... yet.
Then you have to make finall test and play a lot of music cd:s and after that you have fixed the problem.
Make notes which cd:s and what track your player don't play properly and use those
cd:s to testing those trimpot changes.
Posted on Dec 30, 2009
Technics SC-CH530 Barely audible CD player
Have you tried cleaning the unit, there are discs to do that, 4 years is a long time?
Dec 26, 2017 | Technics Audio Players & Recorders
Technics SL-DZ1200 NO CD AUDIO TRACK
Lazer is shot, Not reading info from the disc anymore,
Nov 28, 2012 | Technics SL-DZ1200 CD Player
TECHNICS SL HD81 5 CD MULTICHANGER. The multichanger, when a disc is put into any of the five slots, doesn't sound like the disc spins - almost as soon as the draw is closed, NO DISC appears on th
The motor is shot,Or the gears are jamming up in it, Just look for a different one, It will cost you more to have it repaired, I have got good used disc (Players) For $10 to $40 at the most for friends of mine,
Nov 04, 2012 | Technics Audio Players & Recorders
I burned a CD on my PC to keep in my car and it plays OK in the car and on my PC, but does not play on my Technics SL-PD687 5 disc cd player. It's recorded in *.cda format and it's on a CD-RW. Any...
The problem with old CD Players are that they sometimes are a little fidgety when it comes to reading CDRs.
You could try burning a new CD on the lowest possible setting, say 2x or 4x.
Also try changing the CDR brand as some cheap CDRs are prone to not reading in old CD Drives.
Try using a regular CD-R (CD recordable - record only once) instead of a CD-RW (CD rewritable - rewrite multiple times). CD-RW use a different "ink" to write the data to the disc and can be re-recorded/erased a couple of times before it loses its ability to write effectively to it.
Mar 05, 2011 | Technics SL-PD687 5-Disc CD Changer
I buy a used technics sl-pg480a cd player and after i inserted a cd, there is "no disc" on display...i try with different cd's (mp3, avi,...) and it's always the same...i have opened a box and...
If it doesn't turn the disc it can't read the data and 'know' from that there is a compatible disc inserted.
You may have gotten hosed by the seller. Until you get it to play with a commercial music CD I wouldn't try anything non-standard or home-grown. It doesn't play anything but CD-A music so MP3 and AVI discs would not be recognized anyway.
Before you dive in and possibly wreck it, read this...
http://www.repairfaq.org/sam/cdfaq.htm
The manual:
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/model.SL-PG480A
Feb 20, 2011 | Technics SL-PG480A CD Player
My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Apr 15, 2010 | Technics SL-PS770D CD Player
Technics SL-MC7 / Can't play cd's any more!
Friend. Did you try a CD that you purchased from the store? if so and this problem persist, then you need to get you a new player. If the CDs are scratched, some players will not play them, If they are burnt in mp3 format, (or data format) your player may not recognised this also. Please try playig a regular CD that you bought from the store, if this work, then you will need to reburn your music as a regular CD, hoping that the SL-MC700. reads copied. It should. But please checks these steps.
Please let me know what works.
Thank you
Dec 08, 2007 | Technics SL-MC700 110-Disc CD Changer
Technics SL-MC6 CD player
You have to removo all disc
Then turn on the unit and let do the initialization process
May 26, 2007 | Technics SL-MC6 CD Player
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
