I have no reception on my tv - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 65,425 Answers
Making sure you have an antenna attached to the input jack then try changing the source
Posted on Nov 23, 2019
6ya staff
SOURCE:
Quasar television radio combo. ANY way to get channels without a buying a converter. It has screw connections that looks like you are to use some type of uhf transformer type thing. I do not have any of...
I haven't heard of a radio/tv combo since the demise of vhf tv.
A reasonable radio reception could be derived from the vhf tv signal making a usable unit without the bother of an additional aerial. For use with uhf tv the radio would probably need an additional aerial for decent fm radio reception - unless the radio is am only...
You don't say how old your combo is or give any details. I think the screw terminals could be intended to be connected to a 300 ohm balanced dipole aerial for radio reception only or to mount a loop aerial for indoor tv reception only, if the tv is intended for uhf analogue reception.
If the tv isn't equipped with a standard socket for the usual 75 ohm coaxial type aerial lead it is possible the set manufacturer originally supplied an adaptor to fit to those two screws in order to provide a regular aerial socket.
Without a much more detailed description, these are the only comments I am able to make.
Apr 02, 2018 | Quasar Televison & Video
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
Mono stereo function
Tv Speaker; Stereo/dual Reception; Nicam Reception ...
www.manualslib.com > ... > Flat Panel TV > 141K TX > Owner's manual
LG 141K TX) Manual Online: Tv Speaker, Stereo/dual Reception, Nicam ... Stereo. Dual. Mono Sound Selection. In stereo reception if the stereo signal is weak, ...
Video Mode; Audio Mode; Still; Stereo/mono - ManualsLib
www.manualslib.com > ... > LCD-32CA9S > Owner's manual
Dec 21, 2015 | Televison & Video
I have lost digital reception. I can play DVDs and get analogue TV.
You need to make sure your reception is strong enough to receive digital reception otherwise you will only receive analogue reception and dvd playback ability is normally nothing to do with the TV's reception.
Ensure you have strong reception before doing an auto tune to search for the channels. Good luck.
Sep 14, 2010 | Sony KDL-52XBR9 52 in. LCD HDTV
Some channel no sound
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
Jun 18, 2010 | Sanyo Televison & Video
Can't get reception. Unplugged everything...EVERYTHING...including dish..reconnected, cleaned card and in dish pointing cannot regardless of respondent, cannot get reception HELP
Getting reception for you is not something we can conjure up. Therew could be a million resons why u cant get reception including a damaged TV receiver or a damaged Disk receiver, broken coax etc etc etc.
You can buy a meter that connects in line between the dish and the Tv that will measure any signal being received for about $20. But is no guarantee that the TV is not faulty even if you see a good signal on the display.
Often better to engage a Tech on site than fall off the roof and become a para or electocute yourself playing around inside the TV.
Life is more valuable than saving a few bucks on a tech!
Aug 01, 2009 | Televison & Video
Does a HDMI cable help with reception
No, this will not make a difference with tv reception, just better picture when the reception comes in.
Jun 23, 2009 | iLO 3200 32 in. LCD Television
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
Weak TV reception
get a signal amplifier (radio shack )
Jun 07, 2009 | Televison & Video
Missing channels
no they are not related. ur tv seems to have a defective tuner(inspect also for possible cold solder inside the tuner). remote control can be clean using a cotton swab with a little isoprophyl on it. clean the contact on the pcb.
Jan 14, 2007 | Samsung TXN2745FP 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
