Question about Vacuums
Rug Doctor Portable Spot cleaner stopped spraying. Checked solution tank and sprayer end. Think it is the hose, but can't get off. Help.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 286 Answers
The hose is crimped
Posted on Nov 20, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Bissell ProHeat Clear won't spray from floor nozzels but it does stray from hand cleaner
I agree - just got done fixing 1 of these tonight. The heater plugs up and no spray. Easy Fix, the heater is in the handle and pretty easy to remove. then a straightened paper clip and a blast of air and you should be go to go.
Posted on Apr 19, 2008
Anonymous
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Posted on Jan 20, 2009
VacuumRepair
Chris Jones
  • 438 Answers
SOURCE: Rug Beater isn't rotating during use
This defintiely sounds like your belt has broken or slipped off the motor pulley. The brushes on your vacuum are driven by a belt that attaches to the motor shaft on one end, and the roller brush on the other end.
If you really do have the Bissell 6594 model that you posted this repair under, then to check your belt, simply turn the vacuum upside down, and remove the four screws from the plate that covers the brushes. The bottom plate will then lift off, and you will have access to the brush and belt area of your machine.
You'll probably notice that the belt is either split completely, or is stretched out, and fallen off the motor shaft. Even if the belt is still completely circular, it may be a good idea to go ahead and replace the belt anyway. We recommend replacing the belt on your vacuum every 6 months even if they don't break, as they don't perform nearly as well when the machine has a fresh, tight belt on it.
The model 6594 uses the Bissell Style 7,9,10, etc. belt. It's the most popular Bissell belt on the market. If you don't already have a new belt handy, here's a link to your belt on our website if you need to purchase one:
Bissell Style 7/9/10/12/14/16 Upright Vacuum Cleaner Belts (2 Pack), Part Number 32074
Here's link to the Bissell Owners Manual for your model that will walk you through step by step how to replace the belt on your machine:
http://www.bissell.com/searchresults.aspx?searchtext=6594 &mode=userguides
I hope that this was helpful. If you have any further questions or concerns, please feel free to use the clarification request form here on Fixya, and I'll be happy to answer any of your follow up questions.
If this was helpful, please be so kind and rate the repair, or leave feedback, this is greatly appreciated by the Fixya community when a helpful answer is written.
Chris Jones
GoVacuum.com
Posted on May 28, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: bissell proheat 2x rug cleaner wont spray water
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: bissell carpet cleaner will not spray the cleaning solution
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
hgjdg
Posted on Sep 30, 2010
Sprayer on portable rug doctor is broken need new one
Fixya does not sell Rug Doctor parts.
Nov 25, 2017 | Vacuums
How to I fix the spray on my Rug Doctor portable.
Please unplug machine and remove all hoses and back flush them with your hose. Let them dry and reassemble. Thank you. Please leave feedback
Jul 13, 2016 | Vacuums
BISSELL LIFTOFF WONT SPRAY CARPET
replace the sprayer you can get one of those at guarantee vacuum and sewing center cheaper than any where else
Mar 21, 2014 | Bissell Lift-Off Deep Cleaner 94Y2
I have a rug doctor blue machine. It will not spray anymore. Great suction. It is connected properly. Any suggestions?
Only two things can be wrong here, either the solution hose is plugged, kinked or undone from it's source, or the pump motor is not working. I'd try the hose first, if you can, take it off at the pump and then turn the machine on. If you get solution pumping out of the unit, then it's not the little pump motor and your problem is in the hose.
Oct 22, 2013 | Rug Doctor Mighty Pro X-3 Ready Pack...
Rug doctor shampooer sprayer quit, I think
You think ? If it did you will have to take it to a vacuum repair shop. That's not a DIY job typically.
Oct 19, 2013 | Rug Doctor Mighty Pro Carpet Cleaner
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
Bissell rug cleaner 25a3 will not spray. How do i fix?
If the pump is engaging, then there may be a kink in the waterline. Follow the path from the supply tank to the sprayer. If that checks out, then there may be a clog. A small piece of debris in the supply tank can end up clogging the nozzle of the sprayer. If your nozzle is removable, that is easy to check and clear up. If it is not, then you have to get a bit more creative. Using a small enough diameter rubber hose and a bicycle pump, you can blow out most debris. Cut the rubber hose to about 1 foot in length. Attache one end to the nozzle ( this may take some doing) and the other to the bike pump. With the supply tank empty start to pump. You should have a modest amount of resistance. If it says "no", then you definitely have a clog. There is really nothing to break so applying more effort to the pump should break loose whatever particles are in the line. Good luck!
Jun 10, 2011 | Bissell 25A3 Upright Vacuum
I have a Bissell pro heat water will not disperse from
If the red spray pieces are not clogged but the Bissell still will not dispense water, then I would say the next most likely causes of your issue was either no soap in the tank, or a burnt out water pump. But since you can get water through the tools, I don't see how that's possible. I think it's still the sprayers. When you say you stuck a needle in the eye holes of the two red spray pieces, did you actually take the two red spray pieces off the hoses to do this? And then after pushing through a needle, did you try blowing through the red spray pieces? If you can't blow air through them, they're still clogged and water won't go through, either. Here's how to get the red spray pieces off the Bissell: Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits. Only work on one sprayer at a time so you can see how it goes back together. As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush. Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.) With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care. When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell. Now do the same for the other red water sprayer. The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It?s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base. You might want to prime the pumps. Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time. Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times. As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it?? Good luck!
Jun 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
