SOURCE: throttle cable
This advice is not model specific, but normally you would remove the air filter and access it that way.
Usually the actual fitting of the cable to the carburettor is pretty fiddly; sometimes it is easier to remove the carb, to do it.
SOURCE: installing throttle cable on Husqvarna 445 chainsaw
Try blocking the throttle arm on the carburetor in the wide-open position with a small stick, then deal with the trigger mechanism. In order to remove the cable from the carburetor, you need to remove the carburetor itself, then unhook the cable end at the throttle arm. Keep track of which fuel hose goes where if you do this. Hope this helps!
SOURCE: i have husqvarna 570 chainsaw that idles but wont
Check all idle settings, if its ok and problem is not sloved check all carburattor gasgets.
SOURCE: My Husqvarna 40 chainsaw does'nt
If there is no spark at the plug it is going to be a replacment ignition unit, there were two different units, an Electrolux ( emab ) unit, and a Phelon unit, they are not interchangable, so you need to get the correct unit.
SOURCE: my husqvarna 435 chainsaw blade wont stop spinning when i let off the throttle
sounds like the idle is to high
