Heating & Cooling Logo
Sharon Carnegie Posted on Nov 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My gas fireplace works fine but the glass on one side gets all black very quickly. What can be causing this to happen?
Not Me
Level 3:
  • Master 3,158 Answers
  • Posted on Nov 19, 2019
Not Me
Master
Level 3:
Answers
3158
Questions
0
Helped
163754
Points
31816
Just a guess without more details of make and model, but your gas-air mix is adjusted badly and you are getting incomplete burning = more soot = black glass.
https://www.hunker.com/12577089/why-is-my-fireplace-glass-turning-black
Lee Hutchinson
Level 2:
Habit-Forming:
New Friend:
  • Expert 89 Answers
Lee Hutchinson
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
89
Questions
0
Helped
29227
Points
245
My guess gas not burning properly should get it checked by qualified gas fitter
5 Related Answers
mrgrzz
Dale Koehn
  • 88 Answers
  • Posted on Jan 25, 2009
SOURCE: Black sot from vent free gas fireplace
Thanks for your question,
your problem is either impingement on your log set, or a product of incomplete combustion, if you notice soot on your logs, then you will need to take them out, clean them, and reinstall them as to not have the flame touching them, you will need to clean the burners as well, make sure nothing is laying across the burners, as this too will cause sooting, as far as incomplete combustion, was this model a natural gas converted to propane or the other way around ? if so who ever converted it, did they adjust the gas valve according to specs? improper adjustment will cause sooting or hooking up a natural gas unit to propane will do this too, I will recommend using (Rutland White Off) to remove any soot from your glass, it works fantastic for this ! any ace hardware will carry it, please do not use windex or any other cleaner on the glass as it will more than likely leave a rainbow affect on your glass once the glass heats up, hope this was helpful to ya, please rate this solution, thanks agai
mr.grzz
Anonymous
  • Posted on Feb 15, 2009
SOURCE: black soot on glass and black smoke comes out
Remove the burner and clean all holes ,typically at the end of the burner is a cheep sheet metal valve.This valve adjusts the air to gas mixture by rotating it to increase or decrease the combustible air intake.Air must be sucked into the burner as natural gas is injected into it, this makes for a clean flame,The flame should be blue with small yellow tips.If the flame is long and yellow and sooty increase the air intake on the burner valve.
Anonymous
  • 92 Answers
  • Posted on Apr 13, 2009
SOURCE: soot on glass,outside vent and on walls of fireplace
you have a problem with combustion.unit is not burning properly you should turn unit off and call a pro the life you save may be your own
Anonymous
  • 232 Answers
  • Posted on Dec 04, 2009
SOURCE: Just boughta used home with a gas fireplace that
the cold air in the sealed box is going to condense on the glass at start up but should go away after 10 or more min.
Anonymous
  • 2501 Answers
  • Posted on Jan 06, 2010
SOURCE: HOw do I clean the inside glass of my fireplace?
The decorative surround of your fireplace should easily be removed (if it is anything like mine) and you should then see a number of fixing screws which hold the glass in place.
Remove these and the glass will come out (take care not to let it fall).
2answers
My fireplace glass is cloudy and won't come clean?
this is all i can find out.
How to clean the glass of your Direct Vent Gas Fireplace
  1. Following the instructions in your manual, turn off the fireplace including the pilot light, and open the glass front.
  2. Leave the glass front on its hinges if on hinges. ...
  3. Use a cream cleanser like Imperial Gas Fireplace Glass Cleaner.
More items...
How to clean the glass on your Direct Vent Gas Fireplace - Napoleon ...
napoleonfireplaces.com/clean-glass-direct-vent-gas-fireplace/.
or go to this link might help you.
how to clean cloudy gas fireplace glass Google Search
Oct 30, 2017 • Dishwashers
3helpful
2answers
How do I clean the inside of the glass of the fireplace?
Crumple up newspaper, use it like a rag, scrubbing the glass. Not abrasive enough to scratch the glass but enough to clean soot deposits.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to clean your Fireplace Glass
Gas Fireplace Repair Dirty Glass My Gas Fireplace Repair
How To Clean Your Wood Stove Fireplace Glass
Cleaning glass on woodburner
My gas fireplace's pilot light is on-but when I turn on the electric switch the fireplace will not light all the time. Sometimes it may take 2-3 minutes before it lights up but then goes out after 30...
I had this exact problem.
Open the glass front. Take a piece of fine steel wool and clean the little metal ends where the flames ignite. Sometimes they just get gummed up. It prevents enough flow from getting through to maintain a flame.
I have a black soot on all my walls through the whole house especially the exterior walls. I believe it is caused by my propane fireplace. Im not sure if it is not ventilating properly or what the problem...
Is a Vented or Vent-free gas fireplace? I really suspect it's Vent-free (ventless) as a vented unit, unless the direct vent is clogged exhaust everything, including 85% of the heat out side.
Here are the things that will cause a Vent-free Gas Fireplace to soot.
  • Not having the fireplace cleaned and serviced, at least annually by a qualified technician.
  • Misplaced logs that impinge the main burner flames.
  • Running a ceiling fan at the wrong speed and in the wrong direction while fireplace is burning.
  • Burning scented candles while burning the fireplace.
  • Low Gas Pressure to the burner.
Here are the solutions to the above listed causes:
  • Have the fireplace cleaned and serviced.
  • Check your Owners Manual concerning the proper placement of each log,
  • Run the ceiling fan Counter Clockwise and at the slowest speed. The fan on the side of the switch should be in the UP position for Winter and Down for Summer.
  • Scented candles soot any way. Add the warm moist heat of the Gas Fireplace and they'll soot 50 times worse. The scent is not natural, it has an alcohol base like after shave & cologne. Stop burning scented candles. It has been proven that they greatly contribute to indoor air pollution.
  • Low gas pressure causes incomplete combustion, which causes the burner to soot. Have it checked by your propane provider.
Based on my 15 years in the hearth and home business and having sold and installed hundreds of these appliances, I am will to bet, it's a cleaning and servicing issue or misplaced logs.
Hope this helps you solve your sooting problem. I woud really like to know how it works out for you.
Please let me know at [email protected]
Thanks ... Rich
24helpful
3answers
Black soot on glass and black smoke comes out
mr.grzz
3helpful
Montego gas fireplace
There is a product that I use when servicing gas fireplaces that works pretty good. Google search "Rutland White Off". In a lot of cases it takes just about everything off and the glass looks brand new. If it went to long without being cleaned, it could be permanently baked into the glass. As far as removing the glass, every manufacturer uses there own style of clip. Check around the bottom of the fireplace where the controls are for a latch or possibly screws that are holding it in place, sorry, without looking at it, it's pretty hard to answer that part of your question
Top Heating & Cooling Experts
Paul Carew
john h
