55 inch TCL black screen. What module is the problem?
Black screen on my TCL 55 inch. Common cause is the T-Con board but my 55s405teaa service model doesnt appear to have one after taking all the back panels off. Wondering what modal could be the cause of the black screen. Powers up and has sound. Did a factory reset with no help.
6ya staff
SOURCE:
Lashawn Robinson
  • 1153 Answers
SOURCE: hitachi 51g500 screen gone black
Yes worth repairing but not a crt problem. the crt's are powered by a high voltage transformer and sometimes it's caps that goes bad and in turn knocks out the crt's. but they are ok, it's in the high voltage line.
Posted on Aug 12, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: 55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Posted on Mar 28, 2008
roety
Eric Rotmil
  • 587 Answers
SOURCE: i have a mitsubishi 55 inch tv model ws-55313 i
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the convergence ICs replaced.
A repairman would charge about $350 to replace them
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Nov 20, 2009
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
Posted on May 11, 2012
vikas verma
  • 504 Answers
SOURCE: Sony Wega 55 inch LCD (bought 2006). Screen goes black
video signal not recognize by tv check signal cable
Posted on May 17, 2012
Tcl L42e9adf tv half screen black at startup will go to full screen after 1/2 hour
Hi!
Can be a lot of things. 1- Check the power supply board, 2- Check the backlight circuit, 3- Try to change the T-con board. Good luck,
Serge.
Nov 01, 2016 | Televison & Video
Fix TCL LED TV
Can be T con board or the LCD panel itself . Only be able to confirm by replacing the tcon board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Seach for TCON Board article
http://electro-medical.blogspot.com/
Mar 21, 2016 | Televison & Video
TCL model L40S4690E. Why does TCL logo appear on screen and nothing else happens?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 30, 2016 | Televison & Video
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
How do i fix my tcl 32 inch led tv? When i turn it on the screen display is ok minutes later the screen turning to white. Pls help me how to fix it. Thanks in advance
The T CON board or the LCD panel is faulty. In almost all the 32 inch tvs the TCON board is integrated to the LCD panel and is only replaceable along with the LCD panel.
Jan 02, 2016 | Televison & Video
Where do the two ribbon cables that come off the main board and run down to center of the frame on my LG 55 inch tv model # 55lm7600-ua I only see a place to attach one of the cables.
I changed the t-con and ribbons on the 55" model precedeing this one and both ribbons terminated at the t-con board, check that it is not hidden beneath a large aluminum square metal plate
Dec 02, 2015 | LG Televison & Video
What could have a failed on my Samsung LCD TV to cause 2 pixel wide black horizontal lines on the screen.
TRY T-CON TEST PATTERNS TO ELIMINATE MAIN BOARD
search the model number for t-con test paatterns in service mode
Dec 16, 2014 | Samsung Televison & Video
I have an LG LCD 55LH40 tv where the screen went black. My directv was doing some kind of reboot because we had a power outage, bad weather, and it restarted and the tv was on and the screen said the
Good day..
that problem is cause of bad inverter board or T-con board..
If you have backlight the problem is T-con board..if no back light the problem is inverter board..
Hope it helps..
Jun 13, 2012 | LG 55LH40 55 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
