SOURCE: Pride Legend surges at any speed & makes a clicking noise
This sounds like a bad throttle pot. You need to have it replaced.
SOURCE: Batteries fully charged on pride legend fuses,
Hi ,you need to check whether there are any fuses under the seat,
Does the horn work ? , do the power tiller ? the display showing how much the battery is charged
Regards
GeWiz
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
SOURCE: Trying to troubleshoot a shortage on my Pride
Visit:WWW.ALLDATASHEET.COM .type in your info you require in the correct boxes & you will locate it.& you will find everything you need there as it is all data.
SOURCE: I need a wiring diagram for a 2001 Legend Pride
Me too. Any luck, have the same year three wheeler only getting 6volts at motor.
Local dealer is a joke, wants to overhaul entire unit before fixing the trouble.
