Question about Mitsubishi Televison & Video
Mitsubishi wd73737 TV turns off within 1 min of power up
My mitsubishi wd73737 turns off bout a min r less on it's on after I power it up.. I've been trying everything I'm out of options . How do I reset it r reset the dlp lamp hours. I've unplugged it for 90 secs didnt work I've held down the power button for 10 secs and then turn it back on didnt work .. plz help I need my TV I'm going crazy
    Top Expert:
  • Mitsubishi Master
  • 55,370 Answers
Failing power supply
Posted on Dec 03, 2019
6ya staff
SOURCE:
TVtechmaniac
David Makowski
  • 140 Answers
SOURCE: mitsubishi tv
Check 5A micro fuses F9A04 and F9A05 and if one or both are open replace both convergence IC's part# STK394-250
Posted on Aug 30, 2007
ginko
Ginko
  • 19396 Answers
SOURCE: Green TV timer light flashing and TV does not turn
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 06, 2009
MICHAEL MULLINS
  • 927 Answers
SOURCE: Mitsubishi DLP WD62725 TV after powering down the
Good Day,
More than likey you have bad caps on DM Board.
It willcost about $450 to repair or you can do it yourself,.
On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V,
The DM PCB is on the left hand side of the TV when you take off the back cover.
Good Luck, BIG IRISH,.
Posted on Dec 15, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Posted on Apr 30, 2012
Testimonial: "Thanks SD, I will hook up the air tank and see what happens."
gopakumarg43
  • 76204 Answers
SOURCE: Mitsubishi 73"DLP wd-73638 won't turn on after power outage or getting unplugged
In most cases, this can be due to curropted software [firmware]. Contact the authoriized service center for Mitsubishi. Please do not try to update the software by yourself. It is a very skilled work to this set. Gopakumar Gopalan Google
Posted on Feb 24, 2014
Hi idle after changing sparks plugs
start by checking for a lose vacuum line that is what it sounds like to me u may have pulled one lose and not have seen that u did
Dec 24, 2013 | 1997 Mitsubishi Montero Sport
Color changes on screen mitsubishi wd73737
nothing of that i think it is the power supply some capacitors is bad or screen -tube -
Nov 25, 2013 | Mitsubishi WD-73737 73 in. HD-Ready TV
Tv turns off by itself with an amber or red flashing light. lamp replaced about 6 months ago.
Should be a high voltage or power circuit problem,like transistor too hot,or any component short circuit.
Oct 29, 2012 | Mitsubishi WD73737
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
Hi, Is there a firmware update for my WD73737? If not, is one planned?
The firmware update, 11.03 is now available on the Mitsubishi-TV website.
Nov 19, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Tv will not come on. the green light on the front on the tv blinks, the blue screen come on and the tv shuts off. I've tried the reset procedure. I've unplugged the set for a while. Nothing works. The TV...
First the tv cannot be only 3 months old, (needs chassis rebuilt- send to mitsubishi they do it for around $300) and how did we go from DLP to adjusting screen levels and focus adjusment? PLEASE if you have limited knowledge you will be more helpful if you don't share it.Thanks
May 30, 2010 | Mitsubishi WD73727 73" HDTV
Mitsubishi 62 in 1080p turns on ,has sound but no picture
Your going to need to measure the various power supply voltages to see if its a bad main or power supply board
Nov 08, 2017 | Mitsubishi WS-65513 65" Rear Projection...
Turn on, vibrate, flash lights, turn off
Hi. Just try pressing the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen. After that, plug your device to charger for at least a couple of hours. Hope this helps.
May 22, 2009 | T-Mobile Sidekick II
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
