Hi Can anyone tell me how to Configure Gmail On Apple Platform, Also with the Apple Mail POP, IMAP setting?
SOURCE: gettting mail from yahoo & mail.com to windows live
If you want to receive web-based email that works with outlook then sign up for gmail. They offer free web-based email that will sync up with outlook. :) yahoo and others are not free unless you pay them.
www.gmail.com
SOURCE: i cant get my bellsouth.net
Im assuming you are using outlook express, if not, I apologize, but steps should be similar for other types of software:
Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password
check box. Having Outlook remember your password means that you won't
have to type your password each time you access the account; however, it
also means that the account is vulnerable to anyone who has access to
your computer.
Notes
Good Luck!
SOURCE: setting up windows mail
Use this..
Yahoo Incoming Mail Server (POP3), pop.mail.yahoo.com (port 110)
Yahoo Outgoing Mail Server (SMTP), smtp.mail.yahoo.com (port 25)
Good luck.
Thank you for using FixYa.
SOURCE: setting up a pop server
The normal yahoo account that you currently have when you signed for it by default is not capable for POP Mail. It's only good for web mail access. It can only be allowed to have POP access capability if you upgrade your existing yahoo mail account to Yahoo Mail Plus for the amount of 19.99 USD per year.
The following are the features of Yahoo Mail Plus
- No Graphical ads
- Offline access with POP
- Filters
- No account expiration
- Live customer care
- Mail forwarding
- Address Guard/Disposable addresses
When you have yahoo mail plus enabled these are the settings on your email client
SMTP: smtp.bizmail.yahoo.com port 465
POP: pop.bizmail.yahoo.com port 110
Hope this helps . . .
SOURCE: i have yahoo id i wand configure to my outlook
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
Step to setup an email account on Samsung wave:
1. Press Menu
2. Select My Accounts
3. Choose the type of email account you want to
configure . For Gmail, select "Google "
4. Enter your e - mail address and password and
click " Next "
5. A new window pops up. Select apply without
making any changes.
You will need to configure your
Gmail for IMAP or POP pushing first before authorization is given to your Wave
to accept the pushed mail.
Login to Gmail -> Setting (top right hand corner) -> Forwarding and
POP/IMAP -> Check Enable POP for all mail arriving from now on and check
Enable IMAP.
You are done with configuring GMail side.
Now, add your google mail account under "My Account".
Enter your email (username will be filled up automatically), then your
password.
Next, when you hit the next screen, DO NOT CONFIGURE ANYTHING. Simply
"Set".
Make sure u have POP and SMTP enabled in your mail account before
you try this and yahoo users make sure u enter your mail address as that of
your domain
example : [email protected]
where xx can be something like uk or us or in etc
Hello ,
The problem you are facing in regards server setting is common in email. All you need is to go for the following steps.
Over here i have mentioning the steps for Apple Mail issues i.e Apple Mail POP, IMAP, SMTP Server Setting – Configure Gmail On Apple Platform.
All You need is to adopt steps for these!!!
* Solution 1: Add ‘Add Account’
* Solution 2: Go to google and select a Mail Account and step to continue.
* Solution 3: Login to your gmail with your password.
* Solution 4: Choose Apple Email account associated with your gmail account.
* Solution 5: Go through all the other steps like password, Sms etc
* Solution 6: Choose the Apple email account associated with the gmail account.
Hope these steps would have been enough to solve your query, if not then please refer to the site i have been through
Link- Apple Mail POP, IMAP, SMTP Server Setting – Configure Gmail On Apple Platform
What are the server settings for roadrunner email?
Follow these steps for Roadrunner email POP settings –
• Open Roadrunner webmail on the device and select “settings” option
• Go to the manual server settings and choose POP Settings from there
• Make account type as POP
• The incoming mail server is mail.twc.com
• Incoming server port type is POP3 and port number is 995.
• Security type :None
• Outgoing mail server (SMTP) is mail.twc.com
• Outgoing server port is 587.
• Again Choose Security Type : None
• Finally for the incoming and outgoing user name enter your full e-mail id followed by your email password.
• Now Hit on the “Done” button. Now your Roadrunner e-mail POP server settings has been successfully configured.
https://www.spectrum-login.email/roadrun...
