How to install samsumg WA5471 damper rods - Washing Machines
Diversion 900 damper rod removal?
Hi, Robert for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Fork damper rod removal tool XJRider com
Xj900s Diversion Front Fork Damper Rod Tool Tls009 Fork Tools Tools and...
Yamaha XJ900S Diversion 1994 2004 Workshop Service Manual Download Manuals... $10 cheap
OEM parts for Yamaha
Yamaha diversion 900 XJ900S Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 14, 2017 | Yamaha XJ 900 S Diversion Motorcycles
I have a kenmore side by side. FF side too cold. Replaced t-stat and defrost timer. All settings and air flow set right. FF still too cold. T-stat set all the way down . Should be at 3 or 4
You need to provide a model number in order to look over the parts list and see what type of auto damper your model has. There are ways to test an auto damper to see if it opens and close properly. An auto damper can be electrical or mechanical. Kenmore model numbers look like this example=> 321.2345789 and can be found artound the fresh food compartment door frame.
1 Turn power off to refrigerator.
2 Open the fresh food sections door and remove all items on top shelf.
3 Adjust the fresh food control to its coldest position.
4 Remove the light shield by pulling down on the back corners of the cover and then slide the cover forward.
5 Remove the edge sealing device, radiant shield supporting screws at the back bottom center of the control housing mounting screw at back, bottom center of the control housing. Slide the control housing to the right and lower the housing.
6 Disconnect the temperature control housing from electric quick disconnect.
7 Remove the temperature control housing from the refrigerator and then place on a
flat work surface.
8 Remove the auto damper control rod retainer, control rod and the slide control
gear from the auto damper control.
9 Now turn the control housing over.
10 Remove the two auto damper mounting screws, then remove the auto damper from the control housing.
11 Mark the auto damper rod about 1/4 in. from and away from the housing.
12 Uncoil the auto damper capillary tube at about 4 in.'s
13 Submerge into a glass of ice (not water). then watch for door to move to the closed
position.
14 Remove from ice and warm capillary tube with your hand. Then watch door for an opposite reaction.
15 If no movement is detected, replace the control. 61005971 Damper Control Assembly
The above is only a demostration of how to test a refrigerator with an auto that uses a capillary tube to open and close the damper. Your refrigerator will need to be identified by the correct model number to let you know what type of auto damper your model has, Post your model number and I will tell you what you will need to test yours, Thanks Sea Breeze
Apr 12, 2013 | Refrigerators
Ok- i know that there is no valve adjustment on a 4.3 L vortec- so what is the proper proceedure for tightening the rocker arm nuts?
  • After the rocker shaft assemblies are installed you need to make sure that the ball end of the push rods seat themselves.
  • Now, rotate the engine clockwise until the torsional damper marks line up with the "0" on the timing tab.
  • Now rotate the engine 3 1/2" measured at the damper. At this point the first mark on the damper is now aligned with the first lower water pump bolt.
  • Now install the rocker shaft bolts and snug them to 40 foot lbs.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 11, 2011 | 1998 Chevrolet Blazer
How much fork oil goes in the forks of an 2001 FXD and how do I do this ? Do you have any diagrams to help me with ?
I have no diagrams for you. MAke your own as you take it apart etc and take lots of cell phone pictures if you need help remembering how to put things back together.
Table 1-6. Type E Fork Oil Amounts
MODEL OZ CC IN. MM
FXDXT 11.5 341 6.10 154.9
FXDWG 12.0 356 7.28 184.9
FXDL 10.7 316 7.20 182.9
FXD 10.6 314 6.69 169.9
Changing fork oil is a simple mater for some models and requires fork disassembly for others. Here is the procedure for all 2001 DYNA models:
2001 DYNA FRONT FORK OIL 1.18
REPLACING FORK OIL Replace front fork oil at every 20,000 mile (32,000 km) service interval and/or prior to storage.
ALL BUT FXDX & FXDXT models
Raise and support the motorcycle so the front end is off the floor and the forks are fully extended, on FXDL models, remove the center plug from each fork cap, on all other models, remove the fork tube caps, remove the drain screws from the bottom of each fork and drain the fork oil, replace the drain screws and washers and tighten the screws
to 13-17 in-lbs (1.5-2.0 Nm) THEN see Table 1-6. and fill the fork with Harley-Davidson TYPE E FORK OIL (Part No. HD-99884-80) as set out in the Table. THEN if apart assemble the forks as follows:
a. FXD, FXDXT, FXDWG models: install both fork tube caps and tighten them to 11-22 ft-lbs (14.9-29.8 Nm).
b. FXDL models: install center plugs and tighten until secure.
Fork oil amounts can be measured two ways: use the oz./cc measurement if fork is left in frame; use the in./mm measurement if the fork is disassembled in which case the oil level is measured from the top of the fork tube with the spring removed and the fork fully compressed.
Table 1-6. Type E Fork Oil Amounts for 2001 DYNA
MODEL OZ CC IN. MM
FXDWG 12.0 356 7.28 182.9
PART NO. SPECIALTY TOOL
HD-41177 Fork tube holder
HD-41549A Fork spring compression tool
HD-41551 Spring plate tool
HD-36583 Fork seal installer
HD-59000A Pro-level oil gauge
FRONT FORKS: FXDX & FXDXT 2.20
REMOVAL
Raise and support the motorcycle so the front end is off the floor and the forks are fully extended, remove both front brake calipers and the front wheel, remove the front fender, remove the front fairing, remove the headlamp bracket and attach the headlamp to the frame using a rubber bungee strap, loosen the upper and lower triple clamp pinch bolts and pull the fork sides from the brackets.
DISASSEMBLY
Remove the stopper ring, remove the spring preload adjuster but DO NOT unthread the rebound adjuster from the damper rod because incorrect assembly could result in reduced adjustment range. THEN unthread the fork cap from the fork tube and allow the fork leg to drop, exposing the spring, THEN get a FORK SPRING COMPRESSION TOOL (Part No. HD-41549A) on the spring collar, turn the screws in to engage the holes in collar, compress the spring until the SPRING PLATE TOOL (Part No. HD-
41551) can be positioned between the spacer and the spring collar, THEN hold the fork bolt and compression adjuster, remove the fork bolt from the compression adjuster, remove the spring adjuster plate from the fork bolt, remove spacer, spring collar and spring, pour out the fork oil by pumping the fork leg and rod 8-10 times or until rod the moves freely. THEN position fork slider in vise using a FORK TUBE HOLDER such as (Part No. HD-41177) to avoid damage. THEN remove the socket head bolt, remove the damper from the fork tube, remove the cover from the slider, remove seal and stopper ring, pull the fork tube out of the slider, remove the oil seal, spacer and guide bushing from the fork tube.
CLEANING AND INSPECTION
Measure the fork spring free length and replace the spring if it is shorter than 17.00 in. (431.8 mm), check the fork tube and the slider for score marks, scratches or abnormal wear, check the slide and guide bushings for excessive wear or scratches, set the fork tube on V-blocks and measure runout which should not exceed 0.008 in. (0.2 mm).
ASSEMBLY
Coat the oil seal with TYPE E FORK OIL, before installing the slide bushing and guide bushing, lubricate them with fork oil, THEN install the guide bushing and the spacer seal noting that the guide bushing opening must be oriented to the side and NOT to the front or rear, THEN slip the slider into the fork tube, place the slide bushing over the fork tube until it rests on the slider, drive the guide bushing with the spacer seal into the slider, lubricate a new oil seal with TYPE E FORK Oil, drive the oil seal into the slider using FORK SEAL INSTALLER (Part No. HD-36583). install the stopper ring and dust seal, (if the rebound adjuster was removed from the damper rod bottom the lock nut on the threaded portion of damper rod, holding a thumb on the detent spring and ball, back out (turn counterclockwise) the rebound adjuster to the last "click." and then turn down (clockwise) 17 "clicks", thread the rebound adjuster onto the damper rod until the adjuster stops at maximum thread engagement (but do not force it), thread the locknut onto the damper rod up until it contacts the base of the rebound adjuster and tighten it in place), THEN holding the slider in a vise while being careful not to damage it. install the damper tube into the fork tube and tighten the socket screw and washer to 22-29 ft-lbs (29.8-39.3 Nm). THEN pour half the TYPE E FORK OIL into the fork tube, slowly pump the damper rod 10 or more times, position the damper rod in the fully bottomed position and pour the remaining amount of TYPE E FORK OIL into the fork tube. THEN using a PRO-LEVEL OIL GAUGE (Part No. HD-59000A) or similar adjust the oil level to 5.04 in. (128 mm). THEN carefully clean and install the spring, the spring collar, and the spacers with the sharp edge created when they were stamped out when manufactured, facing the collar. THEN using a FORK SPRING COMPRESSION TOOL such as (Part No. HD-41549A) push spring collar down and place a SPRING PLATE such as (Part No. HD-41551) between the spacer and the spring collar, install the fork cap and tighten it against the rebound adjuster to 22-29 ft-lbs (29.8-39.3 Nm). THEN tighten the fork cap onto the fork tube to 11-22 ft-lbs (14.9-29.8 Nm), install the spring adjuster plate, replace the O-rings on the spring preload adjuster and lubricate them with fork oil. THEN install the spring preload adjuster and the stopper ring and carefully drive the slider cover into the slider.
INSTALLATION
Insert both fork side assemblies up through the fork stem and bracket and upper bracket and tighten the fork stem bracket pinch bolt(s) to 30-35 ft-lbs (40.7-47.5 Nm). Then re-install the headlamp bracket, install the front fender, install the front wheel and the brake caliper When the motorcycle is again ready for the road adjust the headlamp and road test the motorcycle.
Feb 10, 2011 | Harley Davidson FXD Dyna Super Glide...
My land rover defender steering wheel starts to shake and wobble at about 80-90km/ph and gets worse. I have had the wheel balance and alinement done but it is still there. What other causes could cause...
This is really annoying, happens with most Defenders, but is easily fixed. It is the steering damper. They are never strong enough. Best solution is to fit an additional damper onto the track rod. Remove the track rod protection bracket from under the rear of the front diff, fit a heavier track rod and mount an additional damper on the track rod. The other end of the damper is mounted on the rear of the diff (where the protection bracket was removed). Land Rover specialists such as MR Automotive in Brisbane will send you the required parts. You won't regret doing it!
Dec 02, 2010 | Land Rover Defender Cars & Trucks
How do you remove the forks on a 2001 fxd superglide
Hopefully you will glean all you need to know from this but if you want or need more information or more FXD specific information PLEASE H
Hopefully the information below will be okay BUT if you need any more or any more specific information please post a comment and describe what you want/need.
MODEL OZ CC IN. MM
REMOVAL
DISASSEMBLY
ASSEMBLY
INSTALLATION
Oct 01, 2010 | 2001 Harley Davidson FXD Dyna Super Glide
Is a special tool required to remove inner tie rod from relay rod on 2001 Tahoe.? Also what should torque be?
Relay Rod Removal & Installation To Remove:
  1. Raise and support the vehicle
  2. Remove or disconnect the following:
    • Engine protection shield, if equipped
    • Steering damper from the relay rod, if equipped Note: Use the proper tool in order to separate all the tie rods and the ball joints.
    • Tie rod ends (F) (See: Tie Rod Ends)
    • Idler arm ball stud nut (J) and discard the nut (See: Idler Arm)
    • Pitman arm nut (H) and discard the nut (See: Pitman Arm) Remove the idler arm from the relay rod gm_trk_sub15_idler_from_relay_rod.gif
    • Relay rod from the idler arm ball stud using the J24319-B or other suitable puller Remove relay rod from pitman arm ball stud gm_trk_sub15_relay_rod_rem.gif
    • Relay rod from the pitman arm ball stud using the J24319-B or other suitable puller
    • Relay rod from the vehicle
  3. Inspect the threads on the tie rod ends for damage
  4. Inspect the ball stud threads for damage
  5. Inspect the ball stud seals for excessive damage
  6. Clean the threads on the ball studs
To Install:
  1. Install or connect the following:
    • Relay rod to the vehicle
    • Relay rod to the pitman arm ball stud
    • Relay rod to the idler arm ball stud and make sure the seal is on the stud
    • New pitman arm prevailing torque nut
    • New idler arm prevailing torque nut and tighten the idler arm and pitman arm nuts; Torque to: 46 ft. lbs. (62 Nm)
    • Tie rod ends
    • Steering dampener to the relay rod, if equipped
  2. Lower the vehicle
  3. Check the wheel alignment
  4. Test drive the vehicle to confirm the repairs
Sep 18, 2010 | 2001 Chevrolet Tahoe
Damper pulley,i got it off with a three leg pulley puller. how do you put back on bolt to short to grab any threads an all . should i heat pulley? i tryed starting in on with 2in. cut off woodin doul rod...
The damper is usally installed with a damper installation set these are long all theaded studs with nuts and washers andyou screw in the right threaded stud and then install the damper then thewashers and then the nut tightening the nut to pull the damper on. It's very inportant to line up the key exatly as if oof just some it won't go on. I've all ways been able to clean everything with blaster line up the key carefully and tap it on with a light hammer just far enought to start the bolt then keep tapping as you tighten the bolt to help not stripping the thraeds as it's still staring as only t few threads are pulling after its halfway in you can turn it with an impac but tapping with the hammer may still help. heating the damper is riskly to do as the rubber insulation may get too hot and fail the rubber. You can dress the crank nose with a file but you need to do it carefully and evenly scraches made by sandpaper or poorly guilded file can make the shaft bigger as in sven tighter too get the damper on blaster and a rag rubbing both parts is safeest
Mar 21, 2010 | 2000 Plymouth Neon
Recently i put new chrome upper and lower forks on my 2008 ultra classic noticed a small oil leak at the bottom of the right fork a 6mm allen head bolt with a flat brass washer, washer needs to be...
if you have removed spring , then should be able to compres fork leg to see gap round damper rod , wedge a round tube of wood between gap rod and inner wall of fork stantion , that should stop it turning.
Sep 01, 2009 | Harley Davidson FLHTC - FLHTCI Electra...
Remove/replace shock absorber assembly 900s 1995 saab
  1. Slightly loosen hub center nut when all four wheels are on ground.
  2. Raise and support vehicle, then remove five wheel bolts and wheel.
  3. Remove hub center nut, then the wheel sensor,
  4. Press back brake piston using slip-joint pliers,
  5. Remove caliper from steering swivel member, then suspend in wheel housing with cable tie.
  6. Remove brake disc and back plate, then slightly loosen tie rod end nut.
  7. Press out tie rod end nut using puller tool or equivalent.
  8. Remove nut and tie rod end bolt, then the anti-roll bar to swinging arm nut.
  9. Remove outer ball joint nut.
  10. Press ball joint out of steering swivel member using puller tool or equivalent, installed on spring link.
  11. Remove nut and discard. This self-locking nut must not be reused.
  12. Remove three upper mounting nuts for MacPherson strut, then the strut.
  13. Clamp MacPherson strut in vice.
  14. Compress spring using spring compressor or equivalents.
  15. Hold piston rod and remove nut using MacPherson strut socket tool 89 96 662, or equivalent. This is a self-locking nut and must not be reused.
  16. Remove mounting and top spring seat, then the coil spring, gaiter and compression stop.
  17. Unscrew damper using wrench tool No. 89 96 670, or equivalent, then remove damper from strut.
  18. Reverse procedure to install, noting the following:
    1. Screw damper in place using wrench tool No. 89 96 670, or equivalent.
    2. Lower end of coil spring should abut against stop in bottom of spring cup.
    3. Position MacPherson strut on vehicle and install three retaining nuts on top mounting. Tighten nuts alternately, according to specifications.
    4. Always use new hub center nut with self-locking threads.
Jun 04, 2009 | 1995 Saab 900
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
