what kind of vehicle? Usually when that happens either the window glass it rubbing against the stops or stabilizers and the window thinks there is something in the way and is stopping. Sometimes the auto function is out of sequence. Try pushing the up button and holding it for a few seconds and then auto it down. That might solve the sequence problem.
You ask:
Which tense(?) allows for the sequencing(?) of two or more noncontinuous event[s] that occur m[in] the same time period(?)[interval?]
Ambiguous wording as phrasing aside, did you mean the question as a grammar question; or is there some connection to computers. If the former, kindly re-post to appropriate forum and add explanatory detail to make question intelligible to readers. Thanks.
You may want to rename those audio files temporarily. Right click on the audio file, then click on rename, then insert sequencial number at the beginning of filename e.g. 001, 002, 003,.... 020. Then, put in a playlist. They should play in the sequence you want to.
I hope this works for you. Kindly reply for further assistance. Good Luck!
During the start up (before the windows start up) press F2 (or del) key to get to the bios settings. Locate the boot order section. Change the sequence as you wish.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards Please kindly rate this solution Stelios direct fixya link: http://www.fixya.com/users/technical114
Do you have the original start up disc? If so use it. If not there is generally a button to use at start up that will get you to a screen where you can restore your computer to a previous date. The button is usually F10 or F11 or one of the f keys. Also make sure that you don't have a disk in one of the drives. Take everything out and try starting it up. Good luck.
What kind of unit you have will designate what kind of relay it has. Goodman has fanrelay sequencer, Carrier and others have relays and fan boards. So it is one or the other . You will end up calling a service tech. There is only so far you can go yourself without knowledge of the system. Russ
