Question about Intertherm Heating & Cooling
My intertherm electric furnace wont cut off we put new thermostat on
6ya staff
SOURCE:
fixr1st
  • 49 Answers
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Posted on Oct 14, 2007
Anonymous
  • 30 Answers
SOURCE: smoke coming from furnace
You may have something (paper,dust, etc.) on the electric coils. There may also be a short in the element.
Posted on Mar 27, 2008
Anonymous
  • 30 Answers
SOURCE: Intertherm Thermostat
the wire that is on the x- terminal  on the old tstat will be c-terminal on the new tstat.
Posted on Oct 30, 2008
Anonymous
  • 51 Answers
SOURCE: Blower will not shut off on furnace.
If your blower will not shut off from the thermostat, you either have a bad thermostat or your red and green thermostat wires are exposed to each other.
Posted on Feb 20, 2009
Anonymous
SOURCE: heater furnace doesn't want to turn on'
Did the fan turn on, if it did when was the last time you cleaned the filter.
Posted on Mar 14, 2009
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
Intertherm M3rl080A BW furnace that shuts down will no indication of fault
If your diagnostic indicator is not picking showing a fault code than it thinks everything is ok with the furnace. It could be a bad thermostat. (or the heat anticipator in the thermostat).
Jan 30, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
Oct 06, 2010 | Heating & Cooling
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Jan 05, 2010 | Heating & Cooling
Blower will not shut off on furnace. I have a Intertherm FEH-015HA Central Electric Furnace
Feb 20, 2009 | Heating & Cooling
Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Dec 03, 2008 | Intertherm Heating & Cooling
Smoke coming from furnace
Mar 24, 2008 | Intertherm P3RA-048K Air Conditioner
Elec. intertherm FURNACE
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
19 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
Tom Palicke
Level 1 Expert
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
