Televison & Video Logo
J
Jesus Posted on Nov 18, 2019
How much is the screen of a Xerox 2200w monitor?
I want to know the price of only the screen and if it is possible how much cost to reapir it
Chawanwit Klanarong
Level 1:
Habit-Forming:
New Friend:
  • Contributor 26 Answers
  • Posted on Nov 18, 2019
Chawanwit Klanarong
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
26
Questions
0
Helped
10723
Points
75
If your screen is broken, it's not worth repairing.
Xerox lcd modle number 900p Power supply fault plz send pics of supply 1 ic burst i never know number
How-to Fix KDS K917s Model 900P LCD Computer Monitor ...
? 9:59
https://www.youtube.com/watch?v=rkYJS2KhnTc
Jul 5, 2010 - Uploaded by X2YeZCAMCNC
How-to Fix KDS K917s Model 900P LCD Computer MonitorRepair Screen .... This screen has the exact ...
Amazon.com: Ac Dc Adapter Charger for Xerox Model 900 ...
www.amazon.com > ... > Monitors
Amazon.com, Inc.... Model 900 Xl592ds Xg-90d Xl370b Xl-370b Lcd Monitor,xerox Xg-70d 17" Lcd ...Power Supply FOR Xerox model 900 XL592DS XG-90D XG-70D XG-71D ...
1helpful
Monitor Screen shows all blue
Sub another monitor to rule out the video graphics card in the computer, next sub the video cord from the computer to the monitor if possible, if everything checks out replace your computer monitor because the cost will esceed the price of a new one.
Thin red lines have appeared on my samsung 42" plasma tv screen, I've taken it to a reapir guy who said the bottom board had gone and the top board was on its way out he wanted to charge £290.00 to...
There is no term called top/bottom borad in monitor. Lines might have caused becoz of capacitor problem in ur monitor. replacing capacitors will not cost much. try taking ur monitor to someother person
3helpful
MAG 2200W shuts off after 1 second
Sounds like a protection circuit kicking on and off, and it will have to be troubleshot to isolate and replace the faulty circuit, whatever it may be. If you have an extended warranty, try to get it fixed for free. If not, make sure you get an estimate before you pay to have it fixed. Oftentimes the cost of repair will exceeed the cost of a new one, as fast as prices keep coming down these days.
12helpful
3answers
Proview lcd monitor has permanent white screen
I had this exact same problem with the 2200W. I was afraid it was the logic board but that wasn't the case.
I replaced all of the capacitors on the power supply board and now it works perfectly. At first I only replaced the bulging capacitors but that didn't fix it. Most of the bulging caps were the 680's and 470's. It ended up being a 220 (which didn't even look bad) closest to the cluster of 680's.
Save yourself some time and replace ALL of the caps. I used this image from a post on this site as my guide: http://www.ccl-la.com/pl926.jpg
2helpful
Dell 24'' Ultrasharp went blank
I suspect the invertor supplying power to the Xenon backlight tubes has failed.
This can be reapired but may not be cost effective.
Ask for a quote from your local computer specialist but keep in mind the cost of a new monitor.
My LCD screen just went out. Can these be repaired or is it sayonara?
It can be repaired but i will suggest you to buy new one.because reapir will cost almost same the price of new one.
Samsung HL-S5087W DLP picture is distorted
If the picture is distorted it probably needs reapir. I recommend doing a little research to find a reputable reapir shop. You can ask where you bought it or where they sell TV's. If you get two answers the same it might be worth talking to them for pricing.
GNR F173 172 monitor faulty
I think this is the problem of blanking section change the horizantal and vertical blanking transistors.placed near eht.normaly 700 in series and connected with vertical output ic.if they are ok then change vertical output ic.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
