Question about RCA Televison & Video
I have an RCA RTU5540-D that started cycling through colors last night. The remote works and we can hear the tv playing. Tried a few things we found online, none worked. Hoping someone can help!
    Top Expert:
  • RCA Master
  • 10,679 Answers
Try going into tv set up make sure on home not demo
Posted on Dec 10, 2019
6ya staff
SOURCE:
cowboy_pbo
  • 3 Answers
SOURCE: whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Posted on Dec 29, 2007
Anonymous
  • 57 Answers
SOURCE: RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Posted on Sep 24, 2008
GregL
Greg Lumpkin
  • 49 Answers
SOURCE: Memorex MT2024 programing
OK, I and many others have had a problem using this TV with remotes that are not the original (i.e. universal remotes). I have Comcast cable and the remote they gave me with the cable box will operate most of the functions of the TV, but the volume down botton always brings up the TV setup menu.
I solved this by purchasing the Phillips SRU4208WM/17 remote at Wal-mart and teaching it the functions of the original remote by using the Learning mode.
It works great now. Volume up and down, channel up and down, etc.
Posted on Dec 30, 2008
Anonymous
SOURCE: Computer TV output (RCA) - no colour
I had the same problem and nothing worked for me until I changed laptop settings to NTSC_M
So, briefly what I have: S-Video to S-Video cable, laptop (Thinkpad R51, Windows XP, with Intel(R) extreme graphics controler ) and TV set (Samsung, quite old one). The problem was that after connecting my laptop S-Video (4 pin) with S-Video (4 pin) of my TV, I had black and white (no colour) picture.
Solution is the folowing:
- connect your laptop and TV (both S-video 4 pins)
- mouse right click on your laptop desktop screen
- in the popup menu select: 'Graphics Properties'
- "Output to"
- select "TV"
- properties "NTSC_M"
keep in mind that if your are not connected to TV, Graphics Properties don't show TV as an option. So, that was very confusing for me, as I saw similar solution somewhere but was not able to find NTSC_M settings on my laptop
Good luck
Posted on Jan 04, 2009
Anonymous
SOURCE: i need rca rcr312w universal remote durabrand tv codes
HI i have one dvd player im lose the control and i have one universal control no have a book code
and my dvd the brand is only GDS OK I NEED YOU HELP ME THANKS....
Posted on Jan 05, 2009
AH59-02402A REMOTE, WAS WORKING FINE LAST NIGHT AND EVEN THOUGH THE LIGHTS BLINKED ON IT I TRIED NEW BATTERIES STILL WILL NOT CONTROL BOX???
If it show it was doing updates, Thats probably why it wouldn,t work .Once it has updated ,IT will (Probaly) Work (Again)
Nov 07, 2012 | Televison & Video
My RCA TruFlat 27F520T 27" TV started acting up.
The buttons on the tv are the problem. I clipped the prongs on one of mine and fixed it .Just use the remote now
Dec 28, 2010 | RCA TruFlat 27F520T 27" TV
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
My RCA HDTV remote won't work with the regular tv. It was working fine last night until i pressed the tv botton and the volume button.
One thing you can try is to take the batteries out of the remote and then press every button on the remote, then replace the batteries. I have used this technique several times and it works. If that doesn't help try leaving the batteries out over night, this may reset the remote.
I hope this helps.
asnowman
Aug 01, 2009 | RCA HD52W59 HDTV Projection Television
Remote control won't program.
my remote quit working. do you have a solution? thank you
Nov 14, 2008 | RCA 3-Device Universal Remote with...
My new LG LCD TV (3 days old!) suddenly started playing up, last night. I was initially using the receiver unit (with built-in DVD) to play a disc of MPG files, which it did successfully. Then, I tried to...
Good thing the tv is under warranty, theres no magical fix for a problem like this. I would either return it to the store or call for service. If you atempt to do to much to fix it you might voide the warranty, and you should have to do anything to fix it as you said its 3 days old.
Tim Nolan
Sep 24, 2008 | Televison & Video
Need code for rca universal remote i have insignia 40 inch lcd flat screen tv model #NS-LCD40HD-09
I found this site:
http://www.insignia-products.com/universalcontrolcodes.aspx
which lists the universal remote RCA (model RCU807) code as 135
I just bought one of these TV's last night.
Good luck.
Sep 05, 2008 | Televison & Video
TV will not turn on
I am by no means an expert but i have the same type of TV and have a similiar problem, first I thought it might be a heat-induced effect so I vacuumed the interior but no joy--then I carefully inspected the main board and found two components that looked melted. So I would suggest you vaccum the interior and then inspect. But be careful as I found one capacitor on the board that still had a charge after 3 days of the set being turned off, you might want to verify things with a multimeter before poking around.
--Hank Rausch
Jun 15, 2008 | RCA TruFlat 27F520T 27" TV
Failure to start, period.
the whining you hear is most likely the color wheel
it need to reach a curtain rpm before the lamp will kick on
i will almost gurentee one of the colors is broken on the wheel
Mar 12, 2008 | Samsung HL-R5078W 50" HDTV
Televison & Video Logo
54 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
