J
Jessica Smith Posted on Nov 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i connect my tv to my LG arx 8 video receiver
Not Me
Level 3:
  • LG Master 3,158 Answers
  • Posted on Nov 16, 2019
Not Me
LG Master
Level 3:
Answers
3158
Questions
0
Helped
163726
Points
31816
Manuals here
https://www.lg.com/za/support/support-product/lg-ARX8
Depends what inputs and outputs your TV has, and whether you also have a cable box or other source.
Circuit protect fuse
It sounds to me like internal fuse on the power board of the TV. It is usualy a glass cilinder with metal caps on both sides, could be found in any electrical shop or even car-part shops because old cars used same fuses some time ago
How to hook up a denon avr -1706 receiver to a lg smart tv
When connecting your AVR-1706 to your LG TV, you will most likely be limited by the connections on your AVR-1706 as it does not have any HDMI capability.
In this case, depending on your LG TV, you would get the best video performance by using the component video connections from your TV to the Receiver. These are the one labeled Y, Pb, and Pr. These are special cables and you will need 2 sets if you want to run video out of your TV (perhaps you are using the internal tuner). Refer to page 6 of your AVR manual for the TV video inputs. Please note you will only use one type of input such as Component, S Video or Composite (descending order of performance). You must connect the Video Out from your AVR to the back of the TV's Video In as shown on page 6 as a minimum to get signals from devices other than the TV.
On page 12 of your AVR manual you can see the connections for TV outputs including the audio connections to the AVR. In the case of audio, you can either use Optical Digital (Toslink) out from the TV or coaxial (RCA) cables: Again in descending order of performance.
If you don't have the AVR-1706 manual handy, you can see it at the following link: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/033/033AV1706B.PDF
No sound on lg tv when internet pandora is streaming
Be sure the audio out from the roku or whatever box you are using is connected to an available input on the tv. Also, the tv must be set to the same input as you connected to.
Attaching reciever to new hd LG tv...best wiring setup for the Technic without buying new
Only connect audio...you do not have a video option available with this unit but the optimal connection is always audio only between TV-receiver.
Connect any RCA cable jack of your choice from the audio out connection on the TV it may be labeled as "variable audio out" or simply "audio out" into the audio left and right channels of the TV section of your receiver. Be sure the channel connections between the receiver and TV match up and power it all on, connecting is finished.
How do i connect my HDTV to my YAMAHA HTR-5930 receiver? for example i am watching a movie from my usb port on my LG 42LE5300 or i am playing on my xbox, how do i get that sound to come out of the...
The simplest for the movie would be to connect the Optical digital audio out of the TV (above the VGA port) to the Optical Audio In on the receiver. You will need to get this cable from any store that sells TOSLink cables. The manual for the TV is available here: http://www.lg.com/uk/tv-audio-video/televisions/LG-led-tv-42LE5300.jsp . The manual for the receiver is available at the Yamaha support page if you are a registered Yamaha customer: http://download.yamaha.com/search/product/?category_id1=16445&&category_id2=16446&product_id=1060939 .
For the XBox, I'd suggest the same connection if you are using HDMI out on the XBox. If you are using component or composite video, route the audio cables to the receiver's RCA audio in.
I hope this helps.
LG 55LH90 TV to Sherwood RD6500 receiver
That's what manuals are for.
Video Out on the receiver goes to Video In on the TV. That's all you really need.
I recmmend you grab any TV-related audio from wherever its source is for the highest fidelity sound (NOT the TV).
1helpful
I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Connecting LG 50PC3d to Computer
It sounds like you have the resolution of the PC set to an incompatable format for your TV.
Transparent horizontal bar
disconet the ground on the power cord of your tv will fix the problum. or the subwofer power ground .
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
