Question about Siemens Ovens
My Siemens cash power 2000 electricity meter flashes lights and its written error on its screen
It just shuts off as if there is no electricity
    Top Expert:
  • Siemens Master
  • 10,627 Answers
Bad transformer
Posted on Dec 24, 2019
6ya staff
SOURCE:
Is there a reset switch when you are gettng an F20 error code
There are no sort of magic "fix my problem reset buttons" on ANY appliance. Please provide me the model number of your product for the definition of your F20 error code & I'll be happy to help you
May 29, 2016 | Frigidaire 30 in. Electric Gallery Series...
Why won't my double oven lights or power go on?
I think it would be a good idea to find the electric box and then:
1) find the circuit breaker or fuse that controls the oven.
That information is supposed to be written on the inside of the door of the electrical box.
2) Turn off the circuit breaker, or remove the fuse that is supposed to be the one.
3) Pull the oven out from it's place and try to get behind it to test (with an ohm meter or a multi-meter) and see if the unit is getting electricity at all.
Obviously, you will need to turn the breaker back on or screw in the fuse.
BE CAREFUL, THIS IS DANGEROUS STUFF YOU ARE DOING.
Sounds like you may need to reset the circuit breaker ( that means to turn it off and on a few times) or to replace the fuse.
God bless you in your efforts.
Sep 04, 2015 | Maytag MEW6627B Electric Double Oven
My oven is always flashing PF what does that mean
"PF" stands for Power Failure. There should be a reset procedure in your user's manual. I cannot specify this since you don't give the manufacturer or model number of your oven.
Jun 24, 2015 | Ovens
When I turn the oven on it starts to warm but shortly shuts off and flashes EO in the digital screen.
sounds like an error code. your oven ignitor may have gone bad. thats what tells your oven to send gas or power to the oven and turns it on... have that checked. i hope this helps
Aug 13, 2011 | Whirlpool Ovens
Oven won't light and the display is flashing E1 F1
HI. This is essentially a board code(EEPROM check-sum error). Use this check procedure to confirm failure.
1. Safely disconnect the power from the affected unit for five minutes.(Shut of the appropriate circuit breaker or unplug from the wall)
2. Re-apply power and observe for at least one minute.
3. If the code re-appears, replace the main control board (also called ERC or clock).
Jul 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My G.E. electric oven will beep and shut off after 15 min. or so. The read out says "F-2". What is going on?
This is what GE recommends:
“F— and a number You have a function or letter” flash error code in the display • Press the CLEAR/OFF pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the oven for at least 30 seconds and then reconnect power. If the function
error code repeats, call for service.
May 18, 2010 | GE Profile JTP56 Electric Double Oven
Flashing on oven F54 shut off oven at circit
HI. This code is an indication of a shorted upper door latch circuit. This could have be caused by a malfunctioning relay board.
The necessary actions are to gain access to the upper door latch assembly, and test the circuit with a meter. Use the procedure below.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing.
NOTE_ If the upper door latch switch passes the test, simply replace the relay board.
Jan 01, 2010 | Thermador Ovens
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Oven has error E1 F1 will not work
F1 - E1
EEPROM checksum error
1. Disconnect power for at least 30 seconds.
3. If code re-appears, replace control board (also called ERC or clock).
Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
Top Siemens Ovens Experts
Tom Chichester
Marvin
Marvin
David Spradling
David Spradling
Are you a Siemens Oven Expert? Answer questions, earn points and help others
