SOURCE: Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
SOURCE: batteries run down fast
if you are lucky you will get about 40 mins out of it but it will loose it charge when stored
Testimonial: "This was helpful. I was leaving the charged battery stored.and was only getting about 15 min. I will charge before I use now. charles"
SOURCE: black and decker air station won 't work
My Air Station blew a fuse also. The fuse that came with the inflator may be a bit too small amperage wise so I stepped up to .25 Amps more which is just a very small increase.
It is really ill advise to solder a wire in the place of a fuse. You are just asking for it.
The way I did it is I went to my local Radio Shack and got a small fuse holder with red leads and 1.5 Amp fuses. I soldered the fuse holder in place with the new fuse. And now I don't have to deal with any more solder. Just twist the fuse holder, take out the burnt out fuse and replace it with a new one. And wahlah. I'm back in business again.
SOURCE: when ignition turned to on a loud clicking coming
Sounds like a temp door actuator. Does the heater controls move to all positions and change from hot to cold.
Testimonial: "thank i puilled the air con. fuses and problem disappeared and when the 10 amp fuse was reinserted problem came back so i am going with the actuator a"
