Question about LG Washing Machines
LG Washer cycle selection control knob.
Control knob seems stripped. Can't select other cycles.
    Top Expert:
  • LG Master
  • 66,188 Answers
PULL OUT OR PUSH IN ON IT
Posted on Dec 10, 2019
  • robert Dec 11, 2019
    LG front loader Knobs do not push or pull, only turn clockwise or counterclockwise.
6ya staff
SOURCE:
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
Posted on Jun 07, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: GE washer selection knob doesn't engage
The knob it probably stripped. i would replace.
Posted on Mar 10, 2009
prem mathew
  • 1294 Answers
SOURCE: washer fell on face. cracked control panel at cycle selecter knob
Press "end of cycle" for 3 seconds. Its the child lock.
Posted on Mar 15, 2009
marka19
marka19
  • 1430 Answers
SOURCE: I have a Whirlpool Duet
Press and hold the end of cycle button for 15 seconds this should clear it. Control locked
Posted on Sep 23, 2010
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
WFW9200SQ Cycle Control knob
Fixya cannot recommend part numbers.
Jul 27, 2017 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
LG Front Load Washer
This model automatically detects the load size and optimizes the washing time however I do not believe the it should get stuck as you say... try this.. load the washer and then using the control knob.. select Normal.. then push the Quick cycle button on the right.. select the soil level button until it displays 31 minutes.. and run that.. if after you run a wash load it continues to display or get hung up on a specific number such as 7.. your control board may be defective.. If its warranteed.insist they replace it.. Hope that helps...
Aug 10, 2008 | LG WM-2277HW Front Load Washer
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
128 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
