If its mounted under your cupboard the screws are more than likely above the unit inside the cupboards.
Testimonial: "Thank you! We finally did figure that out."
Your model's support page is here, and you can download the installation instructions there:
https://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMV8208BCS&siteCd=WHRCOM&userType=Consumer
The best place to order Maytag appliance parts is from the Pros here: http://www tinyurl.com/gv383
If you have any other questions, for quickest response, feel free to contact me directly.
Ed Miller
[email protected]
http://www.microwavecontrol.com
SOURCE: Broken Handle on Jenn-Air Model M406 Under Cabninet Microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
SOURCE: want to remove an old
There are probably a couple of long bolts still holding it to the brackets on the back wall.
These long bolts are usually accessed through the removeable grill on the front of the microwave.
Just pop off the front plastic grill and then unscrew the bolts underneath. Be sure you have someone to support the full weight of the microwave when you do this since it will probably drop down once you remove these 2 long bolts.
Here is a link to a few other articles with some more tips:
http://wiki.answers.com/Q/How_do_you_remove_an_over-the-range_microwave
http://hubpages.com/hub/how-to-install-installing-an-over-the-range-microwave
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Although most open via a screw at the top or left side of the control panel.
Some require the cabinet / casing to be removed. If there is no visible screws at the top or sides of the control panel. Then the casing will need to be removed.
