Dryers Logo
J
James A Hayes Posted on Nov 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to install a new thermostat for my apartment as I don't have any heat. I bought a replacement, but I don't have the knowledge to perform the install
Robert Wood
Level 3:
  • Master 6,139 Answers
  • Posted on Nov 17, 2019
Robert Wood
Master
Level 3:
Answers
6139
Questions
Helped
1188543
Points
20137
This Old House or Bob Villa online will have video and instructions . YouTube has many appliance and repair videos that will give visual help .
1 Related Answer
Anonymous
  • 667 Answers
  • Posted on Aug 12, 2010
SOURCE: trucks heats up really quick,after
I think you have a blown head gasket, getting oil in the water is an indication of this. Oil pressure is higher than water pressure in the engine. However you should also check the thermostatic fan clutch, when the engine heats up it should activate and the fan should run the same RPM as the engine, when cold it should free wheel. Hope this helps, let me know.
2answers
Bought a rth2300 81012 thermostat as a replacement for a two wire mercury unit for.a gas boiler! Don’t know where the wires go .
We are here to help.
Call 1-800-468-1502 for wiring assistance
this is what you need
Emerson Mechanical Heat Only Thermostat, 1C20-102
1helpful
How do I wire old Fedders single stage heat pump to modern smart thermostat? No aux heat.
Don, the best thing to do is see if there is a unit wiring diagram, if so, then trace out the wires connected to V,F,H,C,T,and X to determine what function they perform.
1990 lincoln town car 5.0 heater won't heat, but the fan and the air conditioner works fine, a new radiator was installed also before i bought it...engine don't seem very hot ..????
If the engine is not getting up to normal temp, I would replace the thermostat. Both heater hoses have to be hot to get heat inside the car.
1helpful
HE heat pump won't talk with old air handler?
The fact is, the air handler supplies the voltage, blower, and electric heat. In order for the heat pump to work correctly, the wiring from the thermostat and heat pump need to be hooked up right to the air handler. The thermostat is what tells which component to come on. If the fan stops, but the condenser keeps going, you either have a faulty fan relay on the air handler, faulty thermostat or wiring, faulty wiring at the heat pump, or the contacts on the new unit are sticking, which is highly doubtful considering it is working now. I hope I have helped you understand this a little more. Good luck and don't let them push you around, get someone that knows what they are looking at.
3helpful
2answers
I recently installed a Honeywell RTH6350D to replace a 2 year old LUX and can get everything to work but the heat(reason for replacing the LUX). Works sometimes but not consistantly. Have the common red(R)...
R represents power supply for the heat system.
RC represents power supply for cooling system.
G represents fan (neutral).
W represents heat system.
Y represents cooling system.
Y2 represents 2nd stage cooling.
W2 represents 2nd stage heating.
AUX represents heat pump.
Try calling 1-800-468-1502.
Their english is "REALLY BAD"!!!
2answers
Can i use current thermostat on the new heating element i just bought
i have a few hundred times'
but ensure you ohhm it out
Oct 22, 2009 • Dryers
Taken to long to dry
IF ELECTRIC
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
IF GAS
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Aug 21, 2009 • LG Dryers
1helpful
GE dryer heating problems
Check the following.
1. Venting
2. Thermostat
3. Heating element
Jun 25, 2009 • Dryers
1helpful
Does not completely dry clothes in the time it used to
For Electric Dryers, check the following---
1. Venting
2. Thermostat
3. Heating element
For Gas Dryer, Check the following---
1. Venting
2. Thermostat
Thermostat problem
Buy some more thermostat cable with the same number of conductors inside it that you need. Twist the wires in the wall to the conductors on the new cable you just bought. Wrap the connections with electrical tape and pull the new cable with the old cable, starting at the furnace. You will then have all brand new conductors to fit to your new thermostat.
Top Dryers Experts
john h
