Sony SPP A2770 Cordless Phone Logo
Posted on Sep 19, 2009
How do you disable the recording after the 10th ring. I want to disable the answering machine all together.
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1316
Points
27
If you want to disable your whole answering machine, then you need to take that up with your phone company. Otherwise, if you want to shorten the amount of rings it takes to get to the answering machine you can go into your options menu on your phone. You can also change your answering machine. Hope that helped! ~~RJ~~
Panasonic phone answering machine not recording. maybe conflict w/verizon voicemail
You can set the answering machine to connect after two rings, or disable the Verizon answering after four rings.
https://www.techwalla.com/articles/how-to-deactivate-verizon-voice-mail
1helpful
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
7helpful
How do you set the amount of rings before answering machine goes on
There's a switch on the back of the machine you can set to have it answer on the second, fourth, or seventh ring. See the illustration at the top right of the first page of the manual.
Can send faxes but not receiving them and yes there is paper in fax
Make sure the correct fax number is assigned on the printer. If you have an answering machine connected to the same line as your fax, configure it so that the answering machine picks up first then the fax. For more information, please refer to this article: Change Number of Rings on Inkjet AIO to Alleviate Issues with Answering Machines.
If you have a voicemail feature associated with the fax line, please disable the voicemail. Voicemail feature and the fax will not work together in the same line.
6helpful
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
The phone ring is heard when a message is taken
It was a fax that I didn't hear until I was home when the answering machine went on. It answered at the same time as the answering machine.
Having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
2answers
GE Telephone answering machine will not work
I'm assuming this is a digital recorder and does not use a tape. Any chance the memory is full and you need to erase messages to free up space for new recordings?
Top Sony Lands Phones Experts
k24674
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
