Question about HP Office Equipment & Supplies
Clean rollers on hp envoy 5534 printer prints white lines on the copy paper
6ya staff
SOURCE:
Inky
Inky Fingers
  • 705 Answers
SOURCE: white lines appear in printing
Try changing the driver settings to a higher or lower quality output. If the problem changes it would suggest that the alignment is till not quite right. This sounds like a BiDirectional mis-alignment issue. You could also try my under head cleaning routine, which is cheap and easy and solves many problems. Review my previous post about cleaning HERE -> http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Posted on Sep 28, 2007
JackHeath
NA NA
  • 1049 Answers
SOURCE: Roller
Try changing completely or at least first cleaning the glassy surface of the toner cartridge first. You can do it with a cotton swab by sweeping the black toner from the surface while manually turning the gear on the side of the cartridge.
Posted on Jul 23, 2008
Anonymous
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
Posted on Jun 20, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: HP OfficeJet J5780 Vertical Black Line Prints when
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Posted on Sep 07, 2009
Anonymous
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
My mp161 is showing a dashed line on the right side of the paper. Visible even if I copy a plain white paper ... dashed line still shows. Checked the pcu. No issue.... checked on the transfer roller... I...
first clean the inside of the printer as there might be tiny strips of paper that cling to the print head assembly, second open the scanning area and clean the camera as tiny lines came from dust that was being read by the camera as an image.
Dec 07, 2013 | Office Equipment & Supplies
How do you clean the rollers?
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x4270 fax machine receives faxes but won't feed paper
Try cleaning the rollers in X4270 printer. You may need to clean the scan lens and the white roller.
1. Unplug the power cord and the phone line from the wall.
Open the control panel.
2. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
3. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
4. Reinstall the white roller.
5. Reconnect the power cord and the phone line.
Next, try to make a standalone copy and let us know the results.
Apr 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
My HP 2900n is turning the white paper gray on everything. How do you clean the roller?
Check the Density settings first and might as well check Brightness and Contrast.
Oct 13, 2008 | HP Color LaserJet 2600n Printer
Two black vertical lines appear on copy, pdf, and scan results
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Black lines
Here you go.
1. Put a paper on the glass don't use the ADF see if you printed copy has a black line on it.
If you do not have a black line on it, do the following.
Lift up the ADF tray go in to additional functions #6 Adjust/Clean and then #2 clean the ADF feeder.
The roller is in the top of the ADF feeder at the right and is white in color. When you press the (set) button you will see it spin.
Also clean the glass you have some whiteout on it. (Look at the glass real good when cleaning it).
Nov 19, 2007 | Canon imageCLASS D880 All-In-One Laser...
Wide black line down middle of paper
I have same problem, with new ink cartridge, also tried cleaning the print head, no luck.
Oct 20, 2007 | Canon PIXMA MP530 All-In-One InkJet...
26 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
