SOURCE: Unlock Phone SAmsung SGH-U700
hi amielle,
if ur have forgotten ur phone lock code, it won work with any sim u insert...u can't go inside d phone, unless d lock is removed, which is possible if u know d code....so take it to an authorised samsung service centre and tel ur problem....they ll remove d lock and restore it to factory settings...because oly they have d software to unlock ur phone....if ur mobile is within warranty period, this would be done at free of cost....
best wishes,
trendsetter
SOURCE: forgot security lock/unlock code and now i cant use my phone at all.
call the phone comp they will eset i for you
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
SOURCE: forgot lock code on LG EnV, need to reset settings for donation
I had the same issue with the same phone. By pure luck, I tried the last 4 digits of the phone number last used on the phone and it worked!
A "soft reset" is triggered by pressing the *#7370# secret
code while the phone is unlock and power on. This secret code will format N73
phone memory (all user data files are deleted) and restore settings to factory
default (thus the lock code will be reset to 12345 again).
