Error code 8 means the SCSI fuse is blown off. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable
- Other SCSI device malfunction
Check if the SCSI cable or other SCSI devices connected to the scanner cause this error.The scanner can work even after this error occurs.
If the issue persists, you may have to contact Authorised Fujitsu Engineer to rectify the error.
Hope the above information is helpful.
Thank you for contacting Fixya.
Regards,
TechSatya
