SOURCE: Canon iR C3220 Printer TCP/IP settings
Wow,
I am not sure why or how I just bumped into this question 8 months later....and why no one has answered your question prior. I hope to God some one has helped you or you bumped into it on your own. If not, press additional functions,system settings, network settings, and the rest is obvious.
SOURCE: won't feed paper while printing
I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
SOURCE: i would like to Reset/Retrieve Password for Copier
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Testimonial: "THANKS A LOT THAT WAS SWEET IT WORK THE MAGIC GOD BLESS"
SOURCE: Canon IR 2270 The copier print
these means that copier cant detect the toner in developing/toner assy.
You should try to reconnect the toner developing assy and try to vacume it.
Also check if the toner bottle is rotating, if yes that means that toner is being dosed and problem is developing assy.
If you do not want to call service write me on [email protected] for service manual.
hope that helps!
Testimonial: "very helpful i just remove check and reconnect the toner cartrige and the issue is solve "
